[Mapserver-users] open failed ogr connection
Andreas Koeberle
koeberle at fh-nb.de
Thu May 13 08:19:15 EDT 2004
Hi
I try do use a access database as a source for a point layer. I check
the ovf file with the ogrinfo like describe in the wiki and the file
seems to work. But when I try do use with the mapserver the following
message <http://dict.leo.org/?p=14/p..&search=appear> appear:
msOGRFileOpen(): OGR error. Open failed for OGR connection
`virtuallayer.ovf'. File not found or unsupported format
I've read this thread http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00728.html.
But also with the binary from Paul Spencer I've got the same error. Is there something wrong with my map file or what could it be?
ovf File:
<OGRVRTDataSource>
<OGRVRTLayer name="layer">
<SrcDataSource>ODBC:user/@margis</SrcDataSource>
<SrcLayer>position</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="Latitude" y="Longitude"/>
</OGRVRTLayer>
</OGRVRTDataSource>
layer:
LAYER
NAME "MyVirtualLayer"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "virtuallayer.ovf"
DATA "layer"
STATUS DEFAULT
CLASS
SYMBOL 1
SIZE 6
COLOR 255 0 0
LABEL
SIZE MEDIUM
TYPE BITMAP
COLOR 0 0 0
END
END
END
system :Win 2000
server: Apache 2
Andreas Köberle
