[Mapserver-users] CGI wierdness w/ relative paths (Revised)
    Chip Hankley
    Chip.Hankley at rmtinc.com
    Thu May 13 07:28:03 PDT 2004
Sorry... made a slight mistype on the last e-mail... when I hardcode
map_web_imagepath it works (not map).
After a little MS hiatus, I'm back. Trying to get up to speed on the
new 4.0 stuff, and using straight CGI. I'm working with Steve Lime's
workshop demo. I was trying to use relative paths to set up the
pointers... but for some reason this isn't working. What's really weird
is that for the first set of hidden variables below (where I'm using
relative paths), some of the images ARE generated (reference map,
scalebars), but the main map is not (shows up as a broken link, and now
image in tmp). When I hard code map_web_imagepath it works.
I would think that when using relative paths, they should always be
relative to the mapserv.exe, right? Why doesn't this work?
TIA!
Chip
THIS DOESN'T WORK
<!-- EDIT THESE HIDDEN VARIABLES -->
<input type="hidden" name="map"
value="..\wwwroot\MapServer\Test1\itasca.map">
<input type="hidden" name="program" value="/scripts/mapserv.exe">
<input type="hidden" name="root" value="/MapServer/Test1/">
<input type="hidden" name="map_web_imagepath" value="..\wwwroot\tmp\">
<input type="hidden" name="map_web_imageurl" value="/tmp/">
THIS WORKS
value="D:\inetpub\wwwroot\tmp\">
Outgoing messages, along with any attachments, are scanned for viruses at RMT prior to sending.
NOTICE--This email may contain confidential and privileged information
for the sole use of the intended recipient.  Any review or distribution
by others is strictly prohibited.  If you are not the intended recipient,
please contact the sender immediately and delete all copies.
More information about the MapServer-users
