[Mapserver-users] postgis and java mapscript
Sean Gillies
sgillies at frii.com
Thu May 13 11:53:30 EDT 2004
On May 13, 2004, at 9:24 AM, Tomas Brandalik wrote:
> I am running mapserver4.0.2 compiled with postgis0.8.1 extension. It
> works fine through cgi but not from java/mapscript.
> java/mapscript library generates expected png file if datasources were
> shapefiles but no output or even error shows up when datasources were
> postgis.
> I can't find any log or whatever would help me find the problem.
> Have anybody seen this before?
> -Tomas
Tomas, mapscript uses the same code as mapserver, so this is unexpected.
Are you using the same map config file in each case? Are you using
mapscript to modify any of the postgis layer's attributes? Setting
filters or classitems?
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
