[Mapserver-users] postgis and java mapscript
Tomas Brandalik
Tomas.Brandalik at Sun.COM
Fri May 14 03:00:50 EDT 2004
sorry, I don't have any dlls I work on suse9.0
-Tomas
Will Richardson wrote:
>Tomas,
>Can you send me the dll you are using and the java classes that utilize
>mapserver? I had problems compiling it and actually found one that works with
>mapserver 3.6.3 but would like to use mapserver 4. Also, does the dll you are
>using include true type support?
>thanks,
>will
>Quoting Tomas Brandalik <Tomas.Brandalik at Sun.COM>:
>>No, I use same map file and generate only simple png without any
>>manipulation. But maybe problem is in compilation libmapscript.so with
>>postgis enabled. I am not sure if I did it properly. will investigate
>>further
>>-Tomas
>>Sean Gillies wrote:
>>>On May 13, 2004, at 9:24 AM, Tomas Brandalik wrote:
>>>>I am running mapserver4.0.2 compiled with postgis0.8.1 extension. It
>>>>works fine through cgi but not from java/mapscript.
>>>>java/mapscript library generates expected png file if datasources
>>>>were shapefiles but no output or even error shows up when datasources
>>>>were postgis.
>>>>I can't find any log or whatever would help me find the problem.
>>>>Have anybody seen this before?
>>>>-Tomas
>>>Tomas, mapscript uses the same code as mapserver, so this is unexpected.
>>>Are you using the same map config file in each case? Are you using
>>>mapscript to modify any of the postgis layer's attributes? Setting
>>>filters or classitems?
>>>Sean
>>>Sean Gillies
>>>sgillies at frii dot com
>>>http://users.frii.com/sgillies
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
