[Mapserver-users] Generating dynamic point layer
IMD Listuser
imd_listuser at comcast.net
Fri May 14 07:30:34 EDT 2004
Im doing something like this.
Basically I am running in a win32 environment and using mapserver base CGI setup to generate maps.
The setup is:
-Web service that accepts new positions from remote clients
-New positions posted to database (SQL Server)
-Service process that periodically connects to the database, selects positions, updates shapefiles.
It's a bit kludgy and I am looking at possibly implementing Post GIS or MySQL, but for the moment it works....
Cheers
Charlie
Charlie Van Dusen
charlie at im-design.net
-----Original Message-----
From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of David Fawcett
Sent: Wednesday, May 12, 2004 10:14 AM
To: samuzzal at linux.net; fx.prunayre at oieau.fr
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Generating dynamic point layer
Has anyone successfully created point layers from Access .mdb files?
David J. Fawcett
MN Office of Environmental Assistance
>>> François-Xavier Prunayre <fx.prunayre at oieau.fr> 5/12/2004 4:47:23 AM
> I have an access table with the georeferencing positions (X, Y).
> Could anybody please help me by sending some code to generate a point
> layer dynamically from these information. Thanks for previous helps I
> got from the group.
You could do that using OGR virtual layer; Wiki page is http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData.
Set DSN in odbc connection; for exemple French, then Ovf file look like this :
<OGRVRTDataSource>
<OGRVRTLayer name="STATIONS">
<SrcDataSource>ODBC:French,STATIONS</SrcDataSource>
<SrcLayer>STATIONS</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS></LayerSRS>
<GeometryField encoding="PointFromColumns"
x="X_LAMBERT_II_ET" y="Y_LAMBERT_II_ET"/> </OGRVRTLayer> </OGRVRTDataSource> where X_LAMBERT_II_ET is X coordinates and Y_LAMBERT_II_ET is Y.
Map file layer tag is :
LAYER
NAME OVF
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "french.ovf"
DATA "STATIONS" # the name of the OGRVrtLayer
STATUS DEFAULT
PROJECTION
"init=epsg:27582"
END
DUMP TRUE
CLASS
TEMPLATE "ttt_query.html"
SYMBOL "circle"
SIZE 6
NAME "STATION_FR"
OUTLINECOLOR 239 16 16
END
END
You could also use Mapscript.
HTH
Francois
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, May 12, 2004 9:27 AM
Subject: [Mapserver-users] Generating dynamic point layer
> Hello group,
> Samuzzal
> _____________________________________________________________
> Linux.Net -->Open Source to everyone
> Powered by Linare Corporation
> http://www.linare.com/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Ce message a ete verifie par MailScanner pour des virus ou des polluriels
et rien de suspect n'a ete trouve.
> Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
> Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
