[Mapserver-users] Accessing uppercase tables with a PostGIS connection
Jeff McKenna
jmckenna at dmsolutions.ca
Fri May 14 10:36:57 EDT 2004
I'm just a little confused again ha. I seem to want to do something so simple yet I'm
stuck again. My PostGIS DB has a table named "CST00SRF", and I simply want to specify
that as the CLASSITEM column in my mapfile. I get this returned when i load the page:
Postgresql reports the error as 'ERROR: column "cst00srf" does not exist '
I've searched the PostGIS and MapServer archives..and found this post by Frank Warmerdam
saying the same thing
(http://postgis.refractions.net/pipermail/postgis-users/2002-May/000995.html). With my
limited C knowledge i still see the line of code there that he had to change in
mappostgis.c. Has this been fixed somewhere? There must be some other way right?
I also found this post suggesting a possible PROCESSING "CASE=IGNORE" parameter setting in
the LayerOBJ
(http://postgis.refractions.net/pipermail/postgis-users/2002-November/001775.html). was
this implemented? didn't work for me.
thanks.
jeff
...humbled again :)
