[Mapserver-users] Transparency issues with ArcIMS Emulator and defined line symbols
Ellis Robin Bundaberg
Robin.Ellis at nrm.qld.gov.au
Sun May 16 20:33:24 EDT 2004
Hi list
I'm having trouble displaying lines 'over-the-top' of other datasets in ArcMap when using Mapserver's ArcIMS emulator and defined line symbols. It seems that when I define a line symbol of my own (to simply allow me to adjust the width/size of the line) the image produced by Mapserver seems to be struggling to portray the transparencies required. This manifests itself in two different ways, depending on how many ArcIMS services are being simulated.
Firstly, if I reference my underlying data (say, polygons) in a separate map file (and therefore map service) to my line data, I find that when I turn on my line data the underlying data is totally obscured by what should normally be a transparent image background. On the other hand, if I reference all data sets in the one map file (as per the layer descriptions from the mapfile given below) I find that turning the line data on doesn't totally obscur the layers beneath, but there problems associated with polygon boundaries appearing transparent when they shouldn't, and with same labels being partially obscured.
The problem seems to be completely associated with the SIZE component of the CLASS object. Even when using a defined SYMBOL (instead of SYMBOL 0) I find the problem doesn't occur when unsing SIZE 1.
I've included a copy of the map file below to give some idea of what's going on. This particular example displays just fine out side of ArcMAP. Any suggestions on how to get around this?
Regards
Rob
# Start of map file
NAME se_tester
STATUS ON
SIZE 600 600
EXTENT 396500 7226000 406500 7233500
UNITS METERS
IMAGETYPE png
IMAGECOLOR 255 255 255
Resolution 96
FONTSET /data4/WWW/mapserver/symbols/fonts/fonts.list
PROJECTION
"proj=utm"
"zone=56"
"ellps=GRS80"
"south"
"no_defs"
END
# Start of web interface definition
WEB
IMAGEPATH /data4/WWW/tmp/
IMAGEURL "http://myserver/tmp/"
TEMPLATE "frmap.php"
END
# Start of reference map
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
POSITION UR
END
STATUS ON
TEMPLATE "legend.html"
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 350 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS KILOMETERS
INTERVALS 10
STATUS ON
END
SYMBOL
NAME "double-line"
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME "Childers Soils (CBW)"
CONNECTIONTYPE OGR
CONNECTION "/data2/aid/region/land/soils/100k/childers/cbw"
DATA "3"
STATUS default
TYPE polygon
METADATA
LAYNAME "Childers Soils"
LAYEXTENT "390500 7179000 450000 7235000"
END
PROJECTION
"proj=utm"
"zone=56"
"ellps=GRS80"
"south"
"no_defs"
END
MAXSCALE 500000
LABELITEM "map_code"
CLASS
# EXPRESSION ([col_group] = 35)
NAME "Kandosols"
COLOR 255 255 128
OUTLINECOLOR 0 0 0
LABEL
COLOR 0 0 0
TYPE truetype
SIZE 8
FONT arial
POSITION cc
force true
WRAP "|"
END #label
END
END # LAYER
LAYER
NAME "100k Contours"
TYPE line
STATUS default
CONNECTIONTYPE OGR
TILEINDEX "/data4/WWW/projects/lwmp/se_grid100k.shp"
DATA "0"
TILEITEM "contours"
LABELCACHE ON
PROJECTION
"proj=utm"
"zone=56"
"ellps=GRS80"
"south"
"no_defs"
END
MAXSCALE 250000
LABELITEM "feature.modi"
CLASS
COLOR 168 112 0
SYMBOL "double-line"
SIZE 2
LABEL
COLOR 0 0 0
TYPE truetype
SIZE 8
FONT arial
POSITION auto
ANTIALIAS TRUE
END # Label
END # CLASS
END # LAYER
LAYER
NAME "100k Drainage"
TYPE line
STATUS default
CONNECTIONTYPE OGR
DATA "0"
TILEITEM "drainage"
PROJECTION
"proj=utm"
"zone=56"
"ellps=GRS80"
"south"
"no_defs"
END
MAXSCALE 250000
CLASS
COLOR 0 112 255
SIZE 2
END # CLASS
END # LAYER
END # Map File
Robin Ellis
Department of Natural Resources and Mines
PO Box 1167
Bundaberg QLD 4670
ph +61 7 4131 5771
fax +61 7 4131 5823
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
