[Mapserver-users] Large Raster files
mapguy
phatsbbnlist at twcny.rr.com
Tue May 18 16:08:31 EDT 2004
I apologize if this repeats, but my web-based mail is quirky.
I have tried all these things and more, and I have arrived at a
solution(s). I would like to share it(them)
1) I used a path within the TILEINDEX shapefile entries similar to the
relative path for the tif files themselves e.g. if everything is in
'data/raster/' where 'data' is the shapefile path in my map file. I
used the command
gdaltindex stlawtst.shp raster/*.tif
from the data directory and stored everything (.tif, .shp, .dbf,. shx)
in the raster directory. The dbf entries for the location field look
like "raster/o4994b.tif" etc
2) I eliminated the "epsg:26918" and inserted a PROJECTION block of proj
style parameters e.g. "proj=utm" "ellps=GRS80" zone=18" "north" "nodefs"
3) I fixed the single tiff layer name typo (that I missed repeatedly)
and so was able to view the single tile sample I had set up as a layer
(changed a zero "0" to a vowel o "o")
Thanks for the responses!
Frank Warmerdam wrote:
> mapguy wrote:
>> I have a question regarding the relationship between PROJECTION and
>> EXTENT for the display of layers in the mapfile (mapserve src 4.02
>> and the new 4.2beta) I have managed to get a custom region working
>> using the mapderve cgi tutorial files as a start. I have successfully
>> displayed and tiled natural color ortho tiffs in EPSG:32115 (NY East
>> state plane), and I have succeeded with a UTM location that displays
>> shape files in EPSG:26918 (UTM 18N NAD83 GRS80).
>> I have downloaded 302 world-file-referenced tiffs with the 1:24000
>> scale topo info for NYS. These are in EPSG:26918 (UTM 18NnAD83
>> GRS80) and the extents, coordinate system and mapping have been
>> verified in my GIS program (grass 5.03). These files will not
>> display, neither as single maps nor as a tiled map, even though the
>> shapefile for the TILEINDEX (with the exact same coord parameters)
>> displays just fine (I even got a county line shapefile map in latlong
>> coordinates to plot properly on the UTM basemap). No errors in the
>> logs. I used .tfw and .wld and internal GeoTiff (gdal_translated)
>> files all with the same null result.
>> I have searched and read the posts on related problems, and it seems
>> I have considered al the possibilities listed. I tried a gdalwarp
>> into state plane (tiff output) coordinates to see if I could
>> "TRANSFORM" it onto the base EPSG:26918 map, but failed to get
>> anything more than the blank map frame.
>> Is there something about UTM and EPSG I am missing, at least as they
>> concern mapserver?
> Mapguy,
> Common problems in this sort of configuration include:
> o Path in the tile index is not absolute. They don't have to be
> absolute, but
> it can be tricky to use proper relative paths in a web
> environment. If files
> are not found, MapServer will often just quietly ignore the fact.
> o Some sort of mixup with the extents. Are the extents in UTM 18 as
> well?
> If the tileindex plots properly this is likely not the problem.
> o Using a MapServer without appropriate format support. For
> instance, if you
> don't have GDAL support you may not be able to display some formats
> of TIFF.
> o Getting the wrong driver. Old MapServers (4.0? at least in 3.x)
> sometimes
> would use the built-in TIFF driver instead of GDAL. The built-in TIFF
> driver only suppose a few variations of TIFF file organization.
> My suggestions for debugging:
> o Turn on debugging and review debug messages. Set the "DEBUG ON" line
> in the MAP object, and in the tileindexed raster layer object. You
> should
> see at least a few debug messages even if things are working just
> fine.
> o Test at the commandline with shp2img program (and debugging enabled).
> o Turn on GDAL debugging when testing with shp2img by setting the
> environment
> variable GDAL_DEBUG to ON. You should see debug messages about
> each TIFF
> file that is actually opened.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
