[Mapserver-users] How can I get the query info programatically?
Stephen Woodbridge
woodbri at swoodbridge.com
Tue May 18 22:36:02 EDT 2004
Oh and one more critical thing to remember is that any layer you want to
query MUST have a TEMPLATE "dummy" or a real TEMPLATE to get any results
returned from it.
-Steve
Paul Spencer wrote:
> Ethan,
> the guts of it (for php mapscript) run something like this (completely
> untested for syntax or logic errors):
> //replace this with whatever your input is and your desired
> //query method, I'm assuming form variables named nX and nY
> //will contain the PIXEL location to query at
> $oPoint = ms_newPointObj();
> $oPoint->setXY( $_GET['nX'], $_GET['nY'] );
> if (@$oMap->queryByPoint( $oPoint, MS_MULTIPLE, -1) == MS_SUCCESS)
> //query returned something, find out what by inspecting each layer
> for ($i=0; $i<$oMap->numlayers; $i++)
> $oLayer = $oMap->getLayer($i);
> $nResults = $oLayer->getNumResults();
> if ($nResults > 0)
> echo "results for layer ".$oLayer->name."<BR>";
> $oLayer->open();
> for ($j=0; $j<$nResults; $j++)
> $oResult = $oLayer->getResult($j);
> $oShape = $oLayer->getShape( $oResult->tileindex,
> $oResult->shapeindex);
> //now you can access $oShape->values as an associative
> //array of key:value pairs
> foreach($oShape->values as $key => $value)
> echo "$key => $value<BR>";
> $oLayer->close();
> else
> //no results for this layer
> echo "no results for layer ".$oLayer->name." :(<BR>";
> else
> //query returned nothing
> echo "no results found on any layer :(<BR>";
> If you get this working, perhaps you could do as Stephen has suggested
> and add it to the accumulated knowledge of MapServerdom ;)
> it is also possible to query just one or several layers directly using
> essentially the same method but accessing the layer object for
> queryByPoint instead.
> Cheers,
> Paul
> Stephen Woodbridge wrote:
>> Ethan,
>> THere are ac bunch of Query examples at
>> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35
>> for mapserver 3.5 but on the bottom is an example mapserver 4.2. Look
>> at the quake.pl I think that does some query stuff.
>> I also check the archives, because this has been asked before. I
>> thought there was a straight forward query example, but I can't seem
>> to locate the one I was thinking of. Once you get your example worked
>> out you might want to post it to the wiki for others.
>> -Steve
>> Ethan Alpert wrote:
>>> Any chance you can be more specific? I've been to the docs several times
>>> looking for how to do this and I'm not finding what I'm looking for.
>>> I need to access information about items that were selected with a
>>> query.
>>> -e
>>> -----Original Message-----
>>> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com] Sent:
>>> Tuesday, May 18, 2004 5:39 PM
>>> To: Ethan Alpert
>>> Cc: mapserver-users at lists.gis.umn.edu
>>> Subject: Re: [Mapserver-users] How can I get the query info
>>> programatically?
>>> Yes, and there are examples. See
>>> http://mapserver.gis.umn.edu/doc.html
>>> -Steve
>>> Ethan Alpert wrote:
>>>> I'd like to get the information of the items selected in a query.
>>>> The template approach isn't quite what I'm looking for. Is there a
>>>> way to extract this info with perl (or php) mapscript?
>>>> -e
>>>> _______________________________________________
>>>> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
