[Mapserver-users] MapServer/gdal doesn't like Photoshop tiff
Till Adams
adams at terrestris.de
Wed May 19 03:55:53 EDT 2004
Dear Jacob,
probably your Photoshop uses a kind of compression per default.
I don't have Photoshop (I use Iview), but when you save your file, it is
important, that you use "no compression" in the options.
Maybe that helps, Till ;-)
Delfos, Jacob schrieb:
> I tried that before, using tfw and wld. Neither worked.....
> -----Original Message-----
> From: Pericles S. Nacionales [mailto:nacional at cbs.umn.edu]
> Sent: Wednesday, 19 May 2004 2:42 PM
> To: Marvin Humphrey
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] MapServer/gdal doesn't like Photoshop tiff
> This happens because photoshop doesn't support GeoTIFF images. When you
> open the GeoTIFF image in Photoshop and then save it again, you lose the
> georeferencing. What you can do to fix it is create what's called a world
> file. This is a small text file with the following lines (this is only
> valid for the example 1.5 image): 0.00473306 0.0 0.0 -0.00473306 -97.3743368
> 49.415919
> If you copy these lines to a text editor and save the file as
> mod09a12003161_ugl_ll_8bit.tfw in the same directory where you have your
> tiff image, your map should then work. To explain the lines briefly: line 1
> represents the X dimension of your pixel (in map units) I don't really know
> what lines 2 and 3 are (don't change it unless you know what you're doing)
> line 4 is the negative Y dimension of your pixel (it has to be negative)
> line 5 is the upper left X coordinate of the image line 6 is the upper left
> Y coordinate of the image
> You can get these info if you have the GDAL utility program "gdalinfo".
> Go ahead and use photoshop to edit the images but make sure to get the pixel
> dimensions and upper left coordinates of the image before doing so.
> Good luck!
> -Perry
> On Tue, 2004-05-18 at 23:00, Marvin Humphrey wrote:
>>Greetings,
>>Problem: I load the mapserver tutorial at
>>http://terrasip.gis.umn.edu/projects/tutorial/ . I take the tiff
>>source used for example1-5.map, scp it off from the FreeBSD 4.9 box
>>running MapServer to a Mac OS X 10.3 box running Photoshop 7.0 and
>>resave it without editing. After scp'ing it back, MapServer doesn't
>>process it anymore -- vector data displays when I load example1-5, but
>>raster data is missing, and the display happens fast enough to suggest
>>that MapServer is simply rejecting the file rather than misinterpreting
>>its contents on a pixel-by-pixel basis.
>>(My eventual goal is to take other raster sources (specifically GLOBE
>>datafiles), turn them into tiffs and process them. This
>>save-with-no-changes operation is for troubleshooting.)
>>I've been through debugging the conflict between the internal tiff
>>support and gdal. (How about making --with-tiff and --with-gdal an
>>illegal compile combination?). MapServer has been recompiled
>>--without-tiff. Here's my config:
>># ./mapserv40 -v
>>MapServer version 4.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>gdal (version 1.2.0) has tiff support, since gtiff is in this list:
>># gdal-config --formats
>>gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem
>>jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk bsb gif jpeg png
>>tiffinfo has this to say about the original image from the tutorial...
>># tiffinfo mod09a12003161_ugl_ll_8bit.tif
>>mod09a12003161_ugl_ll_8bit.tif: Warning, unknown field with tag 33550
>>(0x830e) ignored.
>>mod09a12003161_ugl_ll_8bit.tif: Warning, unknown field with tag 33922
>>(0x8482) ignored.
>>mod09a12003161_ugl_ll_8bit.tif: Warning, unknown field with tag 34735
>>(0x87af) ignored.
>>mod09a12003161_ugl_ll_8bit.tif: Warning, unknown field with tag 34737
>>(0x87b1) ignored.
>>TIFF Directory at offset 0x1152f68
>> Image Width: 3480 Image Length: 1740
>> Resolution: 1, 1 (unitless)
>> Bits/Sample: 8
>> Sample Format: unsigned integer
>> Compression Scheme: None
>> Photometric Interpretation: RGB color
>> Software: "ERDAS IMAGINE"
>> Samples/Pixel: 3
>> Rows/Strip: 8
>> Planar Configuration: single image plane
>>... and this to say about the copy...
>># tiffinfo mod09a12003161_ugl_ll_8bit_mild.tif
>>mod09a12003161_ugl_ll_8bit_mild.tif: Warning, unknown field with tag
>>700 (0x2bc) ignored.
>>34665 (0x8769) ignored.
>>TIFF Directory at offset 0x8
>> Subfile Type: (0 = 0x0)
>> Resolution: 72, 72 pixels/inch
>> Bits/Sample: 8
>> Date & Time: "2004:05:18 19:26:44"
>> Software: "Adobe Photoshop 7.0"
>> Samples/Pixel: 3
>> Rows/Strip: 1740
>> Photoshop Data: <present>, 9182 bytes
>>What is it about the Photoshop tiff that MapServer or gdal doesn't
>>like? It is an 8-bit-per-channel image, just like the original. All
>>image-previews are disabled and ICC profile is not embedded (not that
>>any of that should matter). Contrary to some reports I have unearthed
>>while googling the mail archives, MapServer does not require an
>>indexed-color 8-bit-per-pixel tiff -- because this original is a
>>straight-up 24-bit RGB (3-channel x 8-bits-per-channel = 24-bits-per
>>pixel) image! (I imagine that MapServer must choke on
>>16-bit-per-channel images, like the 16-bit greyscale of GLOBE files, or
>>the 48-bit RGB files used in high-end scanning and image-manipulation.)
>> The problem can't possibly be something as straightforward as
>>byte-order, can it?
>>-- Marvin Humphrey
>>_______________________________________________
>>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
NEU +++ NEU +++ NEU +++ NEU
AveiN! ist Open Source
Lizensiert unter der GNU GPL
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
