[Mapserver-users] MapScript Tests: Argument Error in testShapeCopy
Sean Gillies
sgillies at frii.com
Wed May 19 09:47:40 EDT 2004
On May 19, 2004, at 5:00 AM, Jan Schüngel wrote:
> Hi
> during the Test i get the following error:
> ERROR: testShapeCopy (__main__.ShapePointTestCase)
> Traceback (most recent call last):
> File "tests/testMapScript.py", line 704, in testShapeCopy
> s = self.copyShape(self.shape)
> File "tests/testMapScript.py", line 682, in copyShape
> return shape.copy()
> File "build/lib.linux-i686-2.3/mapscript.py", line 211, in copy
> def copy(*args): return apply(_mapscript.shapeObj_copy,args)
> TypeError: shapeObj_copy() takes exactly 2 arguments (1 given)
> r:
> is the test wrong or whats the problem here ??
Jan,
I think I have written the test improperly. I am not seeing problems
because I am using the next generation API. Starting on line 677 of
the test script, the ShapeObjTestCase should be changed to
class ShapeObjTestCase(MapPrimitivesTestCase):
"""Base class for shapeObj tests"""
def copyShape(self, shape):
"""Try to copy using next generation API, else fall back to
standard API"""
try:
return shape.copy()
except TypeError:
s = mapscript.shapeObj(shape.type)
shape.copy(s)
return s
except:
raise
Please reply when you try this and I'll make sure the change gets
into the final 4.2 release.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
