[Mapserver-users] Python MapScript Tests Problems ("segmentation fault")
Sean Gillies
sgillies at frii.com
Wed May 19 10:28:43 EDT 2004
Jan,
Did you run the tests after the build step? Did you see an ImportError
at that time?
I suspect that the libgdal.so is not in your library path. Did you
install
it after making?
Sean
On May 19, 2004, at 8:21 AM, Jan Schüngel wrote:
> hi,
> now i hab gdal support build in.
> i creat the Mapserver this way:
> ../configure --with-proj --with-gdal.
> make
> so all works fine.
> than mapscript
> python setup.py build
> python setup.py install
> but wit gdal support the import of mapscript dont work
> i get the new error :
> Python 2.3.3 (#2, May 1 2004, 06:12:12)
> [GCC 3.3.3 (Debian 20040401)] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
> >>> import mapscript
> Traceback (most recent call last):
> File "<stdin>", line 1, in ?
> File "mapscript.py", line 4, in ?
> import _mapscript
> ImportError: /usr/lib/python2.3/site-packages/_mapscript.so: undefined
> symbol: CPLFreeConfig
> without gdal support everything works find here, but i need gdal
> support.
> Jan
