[Mapserver-users] Map interpolation
Murilo Lacerda Yoshida
murilo.yoshida at agx.com.br
Wed May 19 21:02:00 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0003_01C43DEC.F74E5A60
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi all,
I wanted to know if mapserver does map interpolation. If not, do you
know a open source tool that does it?
Thanks,
Murilo
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C43DEC.E8EF7580">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EstiloDeEmail17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:70.85pt 3.0cm 70.85pt 3.0cm;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Tabela normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DPT-BR link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DEN-US =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'><span
style=3D'mso-spacerun:yes'> </span>Hi =
all,<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'><o:p> </o:p></span=
></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'> </span>I wanted to know if <span =
class=3DSpellE>mapserver</span>
does map interpolation… If not, do you know <span =
class=3DGramE>a</span>
open source tool that does it?<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'> =
</span>Thanks,<o:p></o:p></span></font></p>
style=3D'font-size:
</span>Murilo<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0003_01C43DEC.F74E5A60--
