[Mapserver-users] Fill Polygons
Paul Spencer
spencer at dmsolutions.ca
Thu May 20 12:19:06 EDT 2004
I should clarify my comment to say that if you want to make a layer 25%
transparent but still have solid outline, you need two layers. If you
are happy with the outlines being 25% transparent, then you only need
one layer. If you want no fill at all, just outlines, then you should
omit the TRANSPARENCY keyword and use either OUTLINECOLOR (on polygon
layers) or COLOR (on line layers)
Paul
Eduardo Spremolla wrote:
> You can define the layer as LINES even if the data are polys.
> LALO
> El jue, 20-05-2004 a las 09:25, Paul Spencer escribió:
>>Note that this makes the entire layer transparent, including polygon
>>outlines. If you want solid outlines and tranparent fills, you will
>>need two separate layers.
>>Paul
>>Bart van den Eijnden wrote:
>>>Hi,
>>>you can use TRANSPARENCY for this, see:
>>>http://mapserver.gis.umn.edu/doc40/mapfile-reference.html
>>>TRANSPARENCY [integer]
>>>Sets the transparency level of all classed pixels for a given layer. The
>>>value is a percentage (0-100) where 100 is opaque and 0 is fully
>>>transparent.
>>>Best regards,
>>>Bart
>>>On Thu, 20 May 2004 13:19:47 +0200, Scott Ainslie <dmi at webmail.co.za>
>>>wrote:
>>>>Can I make the fill color of polygons transparent, ie: able to see layers
>>>>underneath?
>>>>Thanks
>>>>Scott
>>>>_______________________________________________
>>>>Mapserver-users mailing list
>>>>Mapserver-users at lists.gis.umn.edu
>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
