[Mapserver-users] Missing Something
    Eric Katherman
    vaiod at berloy.com
    Fri May 21 11:03:34 PDT 2004
Why doesn't this produce anything, I am a newbie so overlooking something is
very possible. All I get is a 640 480 box the color I have chosen below.  The
sewera files are all in the data path .dbf .prj .shp .shx. I used ogrinfo -al
to get the extents from the shx file.
this is the url I am using.
http://localhost/cgi-bin/mapserv40?map=/srv/www/htdocs/mapserver/test.map&mode=map
test.map contents ---
MAP
  IMAGETYPE PNG
  STATUS ON
  EXTENT 382487.530826 833318.888530 497485.329577 1017509.008264
  SIZE 640 480
  SHAPEPATH "data"
  IMAGECOLOR 238 238 238
END
  LAYER
    NAME sewera
    DATA sewera
    STATUS DEFAULT
    TYPE POLYGON
   END
Any ideas would be appreciated...
Thanks,
Eric
More information about the MapServer-users
