[Mapserver-users] Missing Something
Eric Bridger
eric at gomoos.org
Fri May 21 14:43:59 EDT 2004
On Fri, 2004-05-21 at 14:03, Eric Katherman wrote:
> Why doesn't this produce anything, I am a newbie so overlooking something is
> very possible. All I get is a 640 480 box the color I have chosen below. The
> sewera files are all in the data path .dbf .prj .shp .shx. I used ogrinfo -al
> to get the extents from the shx file.
> this is the url I am using.
> http://localhost/cgi-bin/mapserv40?map=/srv/www/htdocs/mapserver/test.map&mode=map
> test.map contents ---
> MAP
> IMAGETYPE PNG
> STATUS ON
> EXTENT 382487.530826 833318.888530 497485.329577 1017509.008264
> SIZE 640 480
> SHAPEPATH "data"
> IMAGECOLOR 238 238 238
> END
> LAYER
> NAME sewera
> DATA sewera
> STATUS DEFAULT
> TYPE POLYGON
> END
Your ogrinfo output indicates that the data is projected so you must
have compiled mapserver with PROJ4 support and then add to your MAP
section:
UNITS METERS
PROJECTION
"init=epsg:26749"
END
If you search your proj/epsg file you'll find 26749 under # NAD27 /
Arizona Central.
HTH.
