[Mapserver-users] MapInfo -> ogrinfo style and label
Daniel Morissette
dmorissette at dmsolutions.ca
Fri May 21 19:13:35 EDT 2004
Merrett, Mike wrote:
> Style = LABEL(t:"1337",a:265.000000,s:32.001486g,c:#000000,p:1,f:"")
The font is set to "" in this style string. Since MapServer cannot find
a TTF font called "" in your fontset, it falls back on using bitmap
fonts, and bitmap fonts cannot be rotated.
The simplest solution would be to create a font called "default" in your
fontset and the styleitem auto will use that font by default and you
should get your rotated labels.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
