[Mapserver-users] HELP ON ANGLE LABELS
Daniel Morissette
dmorissette at dmsolutions.ca
Fri May 21 19:10:34 EDT 2004
Label rotation works only with Truetype fonts. Your label object is
currently set to use TYPE BITMAP.
Daniel
Marcelo Carrillo wrote:
> Hi Folks,
> I'm trying to put angleled labels on a map of Quito's streets, i'm using
> a shape file, and the angles are in degrees in the .dbf file.
> I think that maybe my layer is wrong, here is it:
> LAYER
> NAME "CALLES"
> GROUP "Ciudad"
> STATUS ON
> DATA "CALLES_84_3_text"
> TYPE ANNOTATION
> MINSCALE 1000
> MAXSCALE 100000
> LABELITEM Textstring
> LABELANGLEITEM Text_angle
> LABELSIZEITEM Text_size
> TOLERANCE 10
> TOLERANCEUNITS PIXELS
> CLASS
> NAME 'CALLES'
> LABEL
> TYPE BITMAP
> ANGLE AUTO
> POSITION LR
> SIZE TINY
> COLOR 10 155 95
> END
> STYLE
> SYMBOL "CIRCLE"
> SIZE 5
> COLOR 255 100 51
> END
> END
> END
> Thanks,
