[Mapserver-users] OGR MapInfo tab {Scanned}
Siki Zoltan
siki at agt.bme.hu
Sat May 22 18:21:23 EDT 2004
Hi folks,
I would like to use MapInfo tab layers in mapserver.
Running Mapserver on a linux box everything is OK, but I have to use a
windows box.
A get the following from mapserver:
msDrawMap(): Image handling error. Failed to draw layer named 'telek'.
msOGRFileOpen(): OGR error. Open failed for OGR connection `c:/Program Files/Apache Group/Apache2/htdocs/xxii/teljes/telek.TAB'. File not found or unsupported format.
Using ogrinfo on the same file I got:
ogrinfo "c:\Program Files\Apache Group\apache2\htdocs\xxii\teljes\telek.tab"
Had to open data source read-only.
INFO: Open of `c:\Program Files\Apache Group\apache2\htdocs\xxii\teljes\telek.tab'
using driver `MapInfo File' successful.
1: telek (Polygon)
OGR is supported:
mapserv.exe -v
MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
If I convert the tab file into esri shape then everything is OK.
I have tried relative and absolute path in the connection string.
Any idea?
Thanks
Zoltan
My Map file:
NAME budafok
EXTENT 642000 225000 651000 234000
SIZE 600 600
IMAGETYPE png
SHAPEPATH "c:/Program Files/Apache Group/Apache2/htdocs/xxii"
FONTSET "c:/Program Files/Apache Group/Apache2/htdocs/xxii/fonts.lst"
SYMBOLSET "c:/Program Files/Apache Group/Apache2/htdocs/xxii/xxii.sym"
UNITS meters
WEB
TEMPLATE "xxii_template.html"
IMAGEPATH "c:/Program Files/Apache Group/Apache2/htdocs/xxii/tmp/"
IMAGEURL "/xxii/tmp/"
HEADER "xxii_header.html"
FOOTER "xxii_footer.html"
MAXSCALE 100000
MINSCALE 100
END
SCALEBAR
IMAGECOLOR 0 0 255
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 0
SIZE 350 10
COLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS METERS
INTERVALS 5
TRANSPARENT TRUE
STATUS TRUE
END
# overview map
REFERENCE
EXTENT 642380 225000 650400 234000
SIZE 325 363
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
LEGEND
KEYSIZE 16 12
LABEL
TYPE BITMAP
SIZE TINY
COLOR 0 0 0
END
STATUS ON
END
# photos
LAYER
NAME "raszter2002"
TILEINDEX "raszter/2002/raszter2002.shp"
TILEITEM "Location"
# MINSCALE 999
STATUS ON
TYPE RASTER
END
# parcelsB
LAYER
NAME "telek"
CONNECTIONTYPE OGR
CONNECTION "c:/Program Files/Apache Group/Apache2/htdocs/xxii/teljes/telek.tab"
DATA "teljes/telek.shp"
STATUS ON
GROUP "telkek"
TYPE POLYGON
CLASSITEM KOZTER_KOD
CLASS
EXPRESSION /0/
NAME 'Magánterület'
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
TEMPLATE "telek_cim.html"
END
CLASS
EXPRESSION /[12]/
NAME 'Közterület'
COLOR 198 198 198
OUTLINECOLOR 0 0 0
END
HEADER "telek_cim_header.html"
FOOTER "telek_cim_footer.html"
END
END # end of map file
