[Mapserver-users] problems loading mapscript dll
Emil Zegers
EZS at DeStraat.NL
Sun May 23 23:13:11 PDT 2004
The problem is probably not the php_mapscript_4.0.2.dll but one of it's dependent dll's.
Make sure you copied the dll's that come with the PHP installer from c:/php/dlls to the windows system directory (c:/winnt/system32). Especially make sure iconv.dll is there.
Also check that the IUSR has sufficient rights on the c:/php/extensions directory.
A handy tool to check dependencies on the fly is filemon from www.sysinternals.com Run it, put a filter on the php_mapscript_4.0.2.dll and check for error messages with missing dll's (file not found).
Emil
>>> "TCHaddad" <TCHaddad at cshore.com> 05/22/04 01:33am >>>
hello all,
we're setting up a new server: w2k/IIS5. PHP4.3.4 installed & tested as OK.
we put php_mapscript_4.0.2.dll in c:\PHP\extensions\
we set extension_dir directive in php.ini to:
extension_dir = "c:\PHP\extensions"
when we then test using dl("php_mapscript_4.0.2.dll"); we get the following error:
Warning: dl(): Unable to load dynamic library 'c:\PHP\extensions\php_mapscript_4.0.2.dll' - The specified module could not be found. in c:\tmp\test.php on line 2
this seems pretty basic, but after trying several locations
we are stumped at this point. Any pointers?
thanks,
tanya
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________
VChecked
______________________________________________________
This message has been checked for all known viruses
More information about the MapServer-users
