[Mapserver-users] raster catalogs with 4.2b3
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Mon May 24 08:32:15 EDT 2004
mapserver at geochem.de schrieb:
> Hi List,
> i did some tests with php mapscript 4.2b3 and found that my raster
> catalogs did not work with this mapserver version.
> The script which works fine with PHP Mapscript 4.0.2. termined with an
> internal server error (Premature end of script headers) when i use
> 4.2b3.
> The type of the Layer is set to MS_LAYER_RASTER. Do i have to use
> MS_LAYER_TILEINDEX now (how?) or what do i have to change to use raster
> catalogs with 4.2b3?
> Many thanks Nicol
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
sounds like a problem I had a few weeks ago. My scripts all worked well
with v4.0.2 and .tif's but when I upgraded I get the same server error.
The problem was that I compiled mapserver with "regular" TIF support and
GDAL TIF support. If there are both you might get that problem so look
in the output of mapserv -v. If you have both then it would be better to
compile the mapserver again with "--without-tiff" option. I did that and
all work fine again.
Regards,
Norbert
