[Mapserver-users] Negative Tolerance?
Ryan, Adam
ARyan at co.linn.or.us
Mon May 24 11:15:46 EDT 2004
Thanks for the reply. I negative tolerance is indeed abstract when applied
to a point.
What I want to do is provide an intersect function; I'm thinking polygons.
For example, a user has selected a parcel feature and wants to select all
the survey features that lie below it. With a tolerance of 0, all the
surveys that only share an edge with the parcel are selected. I want to use
a small negative tolerance so that only those surveys that actually lie
below it are selected.
So far, a negative tolerance is treated as zero. Is there another way to do
this?
Adam
-----Original Message-----
From: David Fawcett [mailto:David.Fawcett at state.mn.us]
Sent: Monday, May 24, 2004 7:21 AM
To: ARyan at co.linn.or.us; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Negative Tolerance?
What are you trying to accomplish?
I don't believe that it would be appropriate or possible to use a negative
TOLERANCE value, as it defines the radius (in pixels) around a point. I
can't picture a circle with a negative radius.
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> "Ryan, Adam" <ARyan at co.linn.or.us> 5/21/2004 12:25:49 PM >>>
List,
Is it possible to use a negative number for a layer's TOLERANCE value?
I
can't seem to make it work.
Thanks.
Adam
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
