[Mapserver-users] WMS server with PHP Mascript
Armin Burger
armin.burger at gmx.net
Tue May 25 08:20:54 EDT 2004
Hi everybody
I'm trying to set up a small WMS server that is based on PHP Mapscript. I need the layers to be created on the fly so I thought this might be an alternative to the CGI WMS built in. I suceeded retrieving an image with a browser or curl e.g.
curl -o test.jpg "http://mspc/mswms/?request=GetMap&layers=image2000/gr_mosaic_full_5.ecw&bbox=281158,4096691,382000,4169443&width=600&height=400&srs=epsg:2100&format=image/jpeg"
But when I want to test the WMS server and include such a layer in a standard MapServer map file I get errors, e.g. with shp2img:
ERROR 4: `d:\www\tmp\10854865609240.img.tmp' not recognised as a supported file format.
msDrawMap(): Image handling error. Failed to draw layer named 'image2000/gr_mosaic_full_5.ecw'. <br>
msDrawRaster(): Image handling error. Unrecognized or unsupported image format <br>
drawEPP(): Image handling error. EPPL7 support is not available. <br>
The PHP page to return the image file uses the header function like
header("Content-type: image/jpeg");
and the map is drawn with
$mapurl = $mapimg->saveImage("");
Does anybody have any ideas what might be wrong? Is there a possibility to see the URL string created by MapServer to download the temporary image or keep the requested image and don't let MapServer delete it?
Thanks for any help
Armin
