[Mapserver-users] Re: Re: [Mapserver-users] raster catalogs with 4.2b3
mapserver at geochem.de
Tue May 25 10:14:02 EDT 2004
Hi Steve, hi list,
i had a build problem.
After i recompiled mapserver with '--without-tiff' as Norbert suggested
the catalog appears correct.
Could you please describe the new way of creating tile indexes a little
bit more detailed?
Many thanks
Nicol
Steve Lime <steve.lime at dnr.state.mn.us> schrieb am 25.05.2004, 15:19:24:
> Although there was new functionality added to 4.2to allow for a new way
> of creating tile indexes in a map file the old method is also completely
> supported. Can you confirm that you don't have a build problem as
> detailed in another response to your message? Can others verify a
> problem? I've not had problems with raster tile setups that I use.
> Steve
> >>> 05/24/04 3:56 AM >>>
> Hi List,
> i did some tests with php mapscript 4.2b3 and found that my raster
> catalogs did not work with this mapserver version.
> The script which works fine with PHP Mapscript 4.0.2. termined with an
> internal server error (Premature end of script headers) when i use
> 4.2b3.
> The type of the Layer is set to MS_LAYER_RASTER. Do i have to use
> MS_LAYER_TILEINDEX now (how?) or what do i have to change to use raster
> catalogs with 4.2b3?
> Many thanks Nicol
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
