[Mapserver-users] Create a legend using PHPMapscript
Hal Mueller
hal at mobilegeographics.com
Wed May 26 14:36:07 EDT 2004
At 15:24 +0200 5/26/04, Frank Broniewski wrote:
> $legend = $map->legend();
> $legend_url = $legend->saveWebImage();
I believe that if you check the value of $legend after that first
line above, it will be 0 (echo $legend;). (my PHP map scripts have
"echo" statements running through them like chicken pox, so that I
can check intermediate results). And the saveWebImage function is
not defined for legends. Try instead:
$legendImage = $map->drawLegend();
$legend_url = $legendImage->saveWebImage();
I'm also assuming that you have a legend defined in your MAP file,
and that you have class names defined in the MAP file. You should
probably post the MAP file and let us have a look at that.
The other thing that I don't see (maybe it's in code farther down) is
some display of that URL. Something like
echo "<img src=\"",$legend_url,"\">";
You also have the option of embedding the legend in the main map's
web image. http://www.mobilegeographics.com/mapserver/usa2.phtml
demonstrates that approach. I would recommend starting out that way
just to get the thing working, and then later you can put it into a
separate image.
Hal
