[Mapserver-users] How does one create .map files?
Ed McNierney
ed at topozone.com
Wed May 26 21:57:35 EDT 2004
Sharyn -
For several years now I've been using the C preprocessor to take
"template" MAP files and do #includes, macro expansion, etc. It's
pretty convenient if you need to either generate lots of MAP files or
lots of layers in a MAP file. We've got around 150+ MAP files, around
60 or 70 layers, and nearly 350,000 source data files, and it is a good
way to keep things organized.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Namnath,
Sharyn
Sent: Wednesday, May 26, 2004 5:55 PM
To: 'mapserver-users at lists.gis.umn.edu'
Subject: [Mapserver-users] How does one create .map files?
Ok, I am so green at this I practically qualify as plant life... I got
through a few good tutorials and didn't die.. but now I am going to try
to use my own (well, ok, ESRI's) shapefiles and data. But how does one
go about creating .map files? By hand? Is there a utility? Also, I
just got some NIMA files which is part of the actual data that I'll be
using. There are also ADRG, CADRG, CIB, & DTED files that I will have
to contend with. Are there utilities out there for an easy conversion
to shapefiles? I will be receiving 3.5 Terabytes worth of data. I
would hate to have to create each .map file by hand...
Thanks in advance for any help anyone can offer.
- sharyn
