[Mapserver-users] French caracters in querybyattributes
gheysen.t at skynet.be
Thu May 27 05:56:10 EDT 2004
-------boundalter150977
Content-Type: text/plain
Content-Transfer-Encoding: 8bit
Hello,
I have try it but I always have the same problem.
Is it still a problem with font encoding on the dbf file ?
the ' is the string delimiter for sql, you shuld escape it like :
\"Braine l'Alleud\". Try it
LALO
El mié, 26-05-2004 a las 05:13, gheysen.t at skynet.be escribió:
> Hello,
> I have hade some problems with french caracters.
> First when I read the results of a query this caracters are not
> correct. I have solve this problem by modify the fonts encoding to
> ISO-8859-1. Thus, now, I can make a query and read the results
> correctly.
> But, I always have a problem with the caracter '. I make a query to
> find the town \"Braine l'Alleud\" and I always have no records. I have
> try with string comparaison et regular mapserver expression but it
> always the same problem.
> Thanks,
> Gheysen Thibaut
Eduardo Spremolla
Antel I+D
Content-Type: text/html
Content-Disposition: inline
Hello, <BR><BR>I have try it but I always have the same problem. <BR>Is it still a problem with font encoding on the dbf file ?<BR><BR>
<HR>
the ' is the string delimiter for sql, you shuld escape it like :<BR>"Braine l'Alleud". Try it<BR><BR>LALO<BR><BR><BR>El mié, 26-05-2004 a las 05:13, gheysen.t at skynet.be escribió:<BR>> Hello,<BR>> <BR>> I have hade some problems with french caracters. <BR>> First when I read the results of a query this caracters are not<BR>> correct. I have solve this problem by modify the fonts encoding to<BR>> ISO-8859-1. Thus, now, I can make a query and read the results<BR>> correctly. <BR>> But, I always have a problem with the caracter '. I make a query to<BR>> find the town "Braine l'Alleud" and I always have no records. I have<BR>> try with string comparaison et regular mapserver expression but it<BR>> always the same problem.<BR>> <BR>> Thanks,<BR>> Gheysen Thibaut<BR>-- <BR>Eduardo Spremolla <EDSPREMOLLA at ANTEL.COM.UY><BR>Antel I+D<BR><BR><BR><BR><BR><BR><BR><BR><BR><br>
-------boundalter150977--
