[Mapserver-users] How does one create .map files?
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Thu May 27 09:04:01 EDT 2004
looking at http://mapserver.gis.umn.edu/contributed.html u will find some usefull tools like MapServer Workbench, MapLab, MapDesk and AveiN!
There's MapEditor at http://software-dkplan.carlbro.dk/mapEditor/
given the amount of data you will have, a good choice could develop a routine to do that automatic/semi-automatic MapFiles generation using languages such as PHP, Python, C, etc... or even inside ArcGIS(if u use it) using VBA.
best
http://www.consultoria.eti.br
UIN: 303747254
I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
***Fim da Mensagem / End of Message ***
On Thu, 27 May 2004 14:30:09 +0200, Norbert Thieme <norbert.thieme at ilmenau.baw.de> escreveu:
> De: Norbert Thieme <norbert.thieme at ilmenau.baw.de>
> Data: Thu, 27 May 2004 14:30:09 +0200
> Para: "Namnath, Sharyn" <NamnatSR at nv.doe.gov>
> Assunto: Re: [Mapserver-users] How does one create .map files?
> Namnath, Sharyn schrieb:
> > Ok, I am so green at this I practically qualify as plant life... I got
> > through a few good tutorials and didn't die.. but now I am going to try
> > to use my own (well, ok, ESRI's) shapefiles and data. But how does one
> > go about creating .map files? By hand? Is there a utility? Also, I
> > just got some NIMA files which is part of the actual data that I'll be
> > using. There are also ADRG, CADRG, CIB, & DTED files that I will have
> > to contend with. Are there utilities out there for an easy conversion
> > to shapefiles? I will be receiving 3.5 Terabytes worth of data. I
> > would hate to have to create each .map file by hand...
> > Thanks in advance for any help anyone can offer.
> > - sharyn
> Hi,
> I haven't looked at all the tools on the utilities page but there could
> be a helpful thing. Have a look at:
> Regards,
> Norbert
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
