[Mapserver-users] PHP/Mapscript problems
Alejandro Vartabedian
avartabedian at webservices.com.uy
Thu May 27 10:44:49 EDT 2004
well,
today i started to inspect the tons of mails archived in this list
folder, i'm subscribed to many, and i think its a good opportunity to
start contributing.
uagn, phpmapscript until i know runs as cgi only and turck-mmcache
don't support cgi.
i can't help you with iis because i use apache.
in apache i run .php files with the php module engine, and an arbitrary
.phmap extension with the cgi php-mapscript version.
it's is easy to do in apache.
perhaps in mapserver website there is a howto for iis, try the
mapserver-wiki.
good luck!
Ugan wrote:
> Hey,
> Im trying to install PHP 4, PHP/MapScript 4.0.2 and MapServer 4.0.2 so that I can use MapLab 2.1-rc3. But (as per normal!) I got a few problems:
> 1. When I try to run .php files in certain directories I get the following error message box:
> [Turck MMCache] Can not create shared memory area]
> I have already set up those directories using my IIS. Any idea how can solve this?
> 2. Can anyone tell me how to properly edit your web server configuration to allow access to
> /maplab-2.0-RC4/... and make sure that index.phtml pages are allowed as default pages (as per Installing MapLab in Windows install instructions?
> 3. PHP doesnt run .phtml files. I have already tried to add .php and .phtml extensions to the Configuration/Application Mapping section in my IIS (as per MapServer PHP/MapScript Installation [http://mapserver.gis.umn.edu/doc/phpmapscript-install-howto.html#example]. Any clues here?
> Your help is SO welcome. Thanks a lot.
