[Mapserver-users] virtual spatial data
Jenu Abraham
jenu_ab at hotmail.com
Thu May 27 17:31:08 EDT 2004
Zac
*-I'm running it under system DSN with administrative privileges
*-originfo didnt work with ODBC text driver - i'm trying to figure out why-
--its unable to initialize
*-originfo virtual.ovf mylayer is returning all of the contents of our
database
another quirk- i would like to mention -though it may not be relevent
before i used to have the latlong table in a database with other user
tables-
when i gave it the command "originfo ODBC:DSN" it showed only
1: some other table name in the database
even though it showed that originfo had opened successfully using the ODBC
driver successfully
-----i'm wondering is there any default table issue associated with
ODBC----?????????
when i put "originfo ODBC:DSN latlong" it didn output the table results
from latlong table even though it said open successful & using driver ODBC
successful
since then i have created a seperate new database with just the latlong
table inside the db--
everything is working fine after that... just as it said in the virtual
spatial data wiki
appretiating the help u are providing
cheers
jenu
>From: Zak James <zak-ms at hoppsan.org>
>To: "Jenu Abraham" <jenu_ab at hotmail.com>
>CC: mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] [mapserver]virtual spatial data
>Date: Thu, 27 May 2004 16:23:22 -0400
>Jenu,
>We were only able to get this to work using a system DSN or a user DSN
>where the DSN owner had 'Power User' or administrative privileges. Ensure
>that your DSN is set up properly and try using it from a variety of
>accounts with different privileges. Were you able to test against the ODBC
>text driver?
>Looks like your GDAL library is up to date, so assuming you're using
>Mapserver 4.2 I'm not sure where the problem lies.
>Is this command:
>returning all of the contents of your db?
>We are looking at how to make this work with file DSNs so that special
>privileges are not required.
>zak
>Zak James
>Applications and Software Development
>DM Solutions Group Inc.
>http://www.dmsolutions.ca
>On May 27, 2004, at 2:56 PM, Jenu Abraham wrote:
>>hi Zac,
>>*-i tried using the file dsn in win 2003 Small business Server-MS -SQL...
>>It didnt work with originfo
>>*-I checked the mapserver.exe using the dependency walker
>>-------GDAL12.dll Product version version - N/A
>>----------------------File ver - N/A
>>---------------------Linker Ver- 6.0
>>--------------------OS ver - 4.0
>>-------------------Subsystem ver - 4.0
>>Other thing u asked to check----
>>*-ogrinfo -ro config.ovf -
>> gave the output --
>>VRT successful 1: mylayer <point>
>>*- ogrinfo -ro config.ovf mylayer
>> - gave the same output as with the command- originfo
>>virtual.ovf mylayer
>>hope this might help in figuring out where the problem lies..
>>thanks
>>jenu
>>_________________________________________________________________
>>Best Restaurant Giveaway Ever! Vote for your favorites for a chance to win
>>$1 million! http://local.msn.com/special/giveaway.asp
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Watch LIVE baseball games on your computer with MLB.TV, included with MSN
Premium! http://join.msn.click-url.com/go/onm00200439ave/direct/01/
