[Mapserver-users] MapScript and Servlet
Umberto Nicoletti
unicoletti at prometeo.it
Fri May 28 03:36:39 EDT 2004
Try copying mapscript.so in /lib or a patch that ld knows
(/etc/ld.so.conf) and then run ldconfig.
If even that does not work export
LD_LIBRARY_PATH=/path/to/dir/containining/mapscript
before starting tomcat.
The tomcat-user mailing list has some good threads on this issue:
http://marc.theaimsgroup.com/?l=tomcat-user&r=1&w=2
You are running the servlet from Tomcat, aren't you?
HTH,
Umberto
On Wed, 2004-05-26 at 23:54, Uchoa wrote:
> Hi,
> I'm working with RH 8, jakarta-tomcat-5.0.19 and MS 4.0.2. I compile
> MapScript with Java and generate a mapscript.jar and libmapscript.so
> (the last I put in /usr/local/lib). In Eclipse, I import the
> mapscript.jar and I try to run the Servlet below to make a test but I
> get a error.
> ###### ERROR ######
> exception
> javax.servlet.ServletException: Servlet execution threw an exception
> root cause
> java.lang.UnsatisfiedLinkError: new_mapObj
> edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
> edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:296)
> HelloServlet.doGet(HelloServlet.java:39)
> javax.servlet.http.HttpServlet.service(HttpServlet.java:743)
> javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
> ####### SERVLET TO TEST ########
> import edu.umn.gis.mapscript.*;
> import java.io.*;
> import javax.servlet.http.*;
> import javax.servlet.*;
> public class HelloServlet extends HttpServlet {
> public void doGet (HttpServletRequest req,
> HttpServletResponse res)
> throws ServletException, IOException
> try
> System.loadLibrary("mapscript");
> System.err.println("Loaded the Mapscript library");
> catch (UnsatisfiedLinkError e)
> e.printStackTrace();
> // mapscript
> mapObj map;
> map = new mapObj ("/var/www/html/itasca/demo.map");
> PrintWriter out = res.getWriter();
> out.println("Hello, Brave new World!");
> out.close();
> Anyone can help me?
