[Mapserver-users] Can't locate object method "TIEHASH"
Lowell Filak
lfilak at medinaco.org
Fri May 28 08:12:07 EDT 2004
It is best to use Perl's XBase module for querying the DBF files.
I'm pretty sure that isn't even documented on purpose - I'll have to
check the doc.
Lowell
The following message was sent by Agneta Schick
<schick at sdac.hannover.bgr.de> on Fri, 28 May 2004 11:54:04 +0200 (MEST).
> Hello mapserver-users,
> I've searched the mail archive and found 2 messages on this topic,
> both were, however, unanswered.
> So I'll try again...
> Platform:
> MapServer 4.0.1
> solaris 9
> Perl 5.8.3
> I want to test an application querying shape files.
> My perl mapscript code
> $layer->queryByPoint($tmp_map,$pnt,$mapscript::MS_SINGLE,1000);
> my $res = $layer->getResult(0);
> $layer->open();
> my $shape=new mapscript::shapeObj($layer->{type});
> my $shape_index = $layer->getShape($shape,-1,$res->{shapeindex});
> my $table =
mapscript::msDBFOpen("/space/b3sn13/webdb/htdocs/ermos/data/usgs.dbf","r+");
> is terminated with
> Can't locate object method "TIEHASH" via package "_DBFHandle".
> Is this a mapscript problem or is something missing in the installation?
> (I tried the same perl script on solaris 8, mapserver 3.6.5, perl 5.6
> and got the same error).
> Thanks,
> Agneta Schick
> Agneta Schick
> Bundesanstalt fuer Geowissenschaften und Rohstoffe
> Federal Institute for Geosciences and Natural Resources
> Stilleweg 2
> D- 30655 Hannover Tel.: +49 511 643 3136
> GERMANY FAX.: +49 511 643 3663
> schick at sdac.hannover.bgr.de http://www.seismologie.bgr.de
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
