[Mapserver-users] Can't locate object method "TIEHASH"
Eric Bridger
eric at gomoos.org
Fri May 28 13:47:16 EDT 2004
On Fri, 2004-05-28 at 12:30, Lowell Filak wrote:
> The following message was sent by Sean Gillies <sgillies at frii.com> on
> Fri, 28 May 2004 08:00:31 -0600.
> > On May 28, 2004, at 6:38 AM, Eric Bridger wrote:
> > > On Fri, 2004-05-28 at 05:54, Agneta Schick wrote:
> > >> Hello mapserver-users,
> > >> I've searched the mail archive and found 2 messages on this topic,
> > >> both were, however, unanswered.
> > >> So I'll try again...
> > >> Platform:
> > >> MapServer 4.0.1
> > >> solaris 9
> > >> Perl 5.8.3
> > >> I want to test an application querying shape files.
> > >> My perl mapscript code
> > >> $layer->queryByPoint($tmp_map,$pnt,$mapscript::MS_SINGLE,1000);
> > >> my $res = $layer->getResult(0);
> > >> $layer->open();
> > >> my $shape=new mapscript::shapeObj($layer->{type});
> > >> my $shape_index = $layer->getShape($shape,-1,$res->{shapeindex});
> > >> my $table =
> > >> mapscript::msDBFOpen("/space/b3sn13/webdb/htdocs/ermos/data/
> > >> usgs.dbf","r+");
> > >> is terminated with
> > >> Can't locate object method "TIEHASH" via package "_DBFHandle".
> > >> Is this a mapscript problem or is something missing in the
> > >> installation?
> > >> (I tried the same perl script on solaris 8, mapserver 3.6.5, perl 5.6
> > >> and got the same error).
> > > This sounds familiar to me but I can't remember the details.
> > > The solution is to not use mapscript's DBF functions. I've never gotten
> > > them to work. Use some other dbase module. I use XBase.pm
> > > http://search.cpan.org/~janpaz/DBD-XBase-0.241/lib/XBase.pm to do all
> > > dbf access of shapefiles.
> > > Eric
> > Will one of you enter this as a new MapScript-SWIG bug? If it turns
> > out that
> > none of us are using the msDBF* functions through mapscript, then I
> > should see
> > about removing them from the module.
> > I too prefer to use XBase much of the time.
> > For querying, use shapeObj::getValue() to get at the attributes of
> > features.
> > The following code
> > for ($i=0; $i<$layer->{numitems}; $i++) {
> > $att_name = $layer->getItem($i);
> > $att_value = $shape->getValue($i);
> > gets attribute names and items. It's a bit awkward that you can't get
> > both from
> > the same object. If you feel strongly about that, file a new feature
> > enhancement
> > in Bugzilla.
> > cheers,
> > Sean
> Can it be removed? I was under the impression that TCL/MapScript needed it.
> Lowell
Well, as far as I can tell, msDBFOpen() is already removed. No trace of
it in mapscript.i. It's not even in any of the docs. So I'm not filing a
bug. Agneta, you can use Sean's suggestion or XBase.pm.
Strange. I know I saw those DBF utility methods somewhere, sometime
