[Mapserver-users] mscalculate() and explode()
julius muchemi
muchemijg at yahoo.com
Sat May 29 08:57:55 EDT 2004
--0-2045783271-1085835475=:67558
Content-Type: text/plain; charset=us-ascii
i have ahead with the project and after displaying the the layer now want to add zoom and pan capabilities to the previous code. I'm still on windows 2000.
i have the following error in browser which i dont know how to solve
Warning: Wrong parameter count for explode() in C:\Program Files\Apache Group\Apache2\htdocs\Nakmap\nakint.php on line 18
Fatal error: [MapServer Error]: msCalculateScale(): Invalid image extent. in C:\Program Files\Apache Group\Apache2\htdocs\Nakmap\nakint.php on line 19
The code looks like this:
?php
dl("php_mapscript_4.0.1.dll");
$map_path = "C:/Program Files/Apache Group/Apache2/htdocs/Nakmap/";
$map = ms_newMapObj($map_path."nakuru.map");
$val_zsize=3;
$check_pan="CHECKED";
<HTML>
<HEAD>
<TITLE>NAKURU MUNICIPALITY MAP: :By ERMIS AFRICA</TITLE>
</HEAD>
<BODY bgcolor="yellow">
<TABLE bgcolor=green cellspacing=0 cellpanding=1 border=2><TR><TD>
<FORM MEHOD=POST ACTION="<?=$php_self;?>">
</TD><TD>
$extent_to_set=explode("EXTENT");
$map->setextent($extent_to_set[0],$extent_to_set[1],$extent_to_set[2],$extent_to_set[3]);
$my_extent=ms_newpointObj();
$my_point->setXY("mapa_x", "mapa_y");
$my_extent = ms_newrectObj();
$my_extent = $map->setextent($extent_to_set[0], $extent_to_set[1], $extent_to_set[2], $extent_to_set[3]);
$zoom_factor=("zoom")*("zsize");
if ($zoom_factor==0)
$zoom_factor=1;
$CHECK_zout="";
$check_zin="";
else if ($zoom_factor<0)
$check_pan="";
$check_zout="CHECKED";
$check_zin="";
else
$check_pan="";
$check_zout="";
$check_zin="CHECKED";
$Val_zsize=abs($zoom_factor);
$map->zoompoint ($zoom_factor, $my_point, $map->width, $map->height, $my_extent);
$image = $map->draw();
$image_url=$image->saveWebImage();
$extent_to_html = $map->EXTENT->minx." ".$map->EXTENT->miny." ".$map->EXTENT->maxx." ".$map->EXTENT->maxy;
Could trace anything wrong with my zoom and pan code. SPecifically this code
and
as seem to be source of all the above errors
Muchemi
Do you Yahoo!?
Friends. Fun. Try the all-new Yahoo! Messenger
Content-Type: text/html; charset=us-ascii
<DIV>i have ahead with the project and after displaying the the layer now want to add zoom and pan capabilities to the previous code. I'm still on windows 2000. </DIV>
<DIV>i have the following error in browser which i dont know how to solve </DIV>
<DIV><BR>Warning: Wrong parameter count for explode() in C:\Program Files\Apache Group\Apache2\htdocs\Nakmap\nakint.php on line 18</DIV>
<DIV>Fatal error: [MapServer Error]: msCalculateScale(): Invalid image extent. in C:\Program Files\Apache Group\Apache2\htdocs\Nakmap\nakint.php on line 19</DIV>
<DIV>The code looks like this:</DIV>
<DIV>?php <BR>dl("php_mapscript_4.0.1.dll");<BR> $map_path = "C:/Program Files/Apache Group/Apache2/htdocs/Nakmap/";<BR> $map = ms_newMapObj($map_path."nakuru.map");<BR> $val_zsize=3;<BR> $check_pan="CHECKED";<BR>?><BR><HTML><BR> <HEAD><BR> <TITLE>NAKURU MUNICIPALITY MAP: :By ERMIS AFRICA</TITLE><BR> </HEAD><BR> <BODY bgcolor="yellow"><BR><TABLE bgcolor=green cellspacing=0 cellpanding=1 border=2><TR><TD> <BR><FORM MEHOD=POST ACTION="<?=$php_self;?>"><BR></TD><TD><BR><?<BR>{<BR>$extent_to_set=explode("EXTENT"); <BR>$map->setextent($extent_to_set[0],$extent_to_set[1],$extent_to_set[2],$extent_to_set[3]);<BR>$my_extent=ms_newpointObj();<BR>$my_point->setXY("mapa_x", "mapa_y");<BR>$my_extent = ms_newrectObj();<BR>$my_extent = $map->setextent($extent_to_set[0], $extent_to_set[1], $extent_to_set[2],
$extent_to_set[3]);<BR>}<BR>?><BR><?<BR>$zoom_factor=("zoom")*("zsize");<BR>if ($zoom_factor==0)<BR>{<BR>$zoom_factor=1;<BR>$check_pan="CHECKED";<BR>$CHECK_zout="";<BR>$check_zin="";<BR>}<BR>else if ($zoom_factor<0)<BR>{<BR>$check_pan="";<BR>$check_zout="CHECKED";<BR>$check_zin="";<BR>}<BR>else<BR>{<BR>$check_pan="";<BR>$check_zout="";<BR>$check_zin="CHECKED";<BR>}<BR>$Val_zsize=abs($zoom_factor);<BR>$map->zoompoint ($zoom_factor, $my_point, $map->width, $map->height, $my_extent);<BR>$image = $map->draw();<BR>$image_url=$image->saveWebImage();<BR>$extent_to_html = $map->EXTENT->minx." ".$map->EXTENT->miny." ".$map->EXTENT->maxx." ".$map->EXTENT->maxy;<BR>?></DIV>
<DIV>Could trace anything wrong with my zoom and pan code. SPecifically this code<BR>$map->setextent($extent_to_set[0],$extent_to_set[1],$extent_to_set[2],$extent_to_set[3]);</DIV>
<DIV>and </DIV>
<DIV>$extent_to_html = $map->EXTENT->minx." ".$map->EXTENT->miny." ".$map->EXTENT->maxx." ".$map->EXTENT->maxy;</DIV>
<DIV>as seem to be source of all the above errors<BR>Muchemi</DIV><p>
<hr size=1><font face=arial size=-1>Do you Yahoo!?<br>Friends. Fun. <a href="http://messenger.yahoo.com/">Try the all-new Yahoo! Messenger</a>
--0-2045783271-1085835475=:67558--
