[Mapserver-users] problems with symbols on lines
Karsten Hoffmann
karhof at web.de
Mon May 31 06:23:48 EDT 2004
This is a MIME encoded message.
--STEFAN40bb07b775e6
Content-Type: text/plain; charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Hello,
I'm experimenting with symbols and I think that there are some problems with drawing symbols on lines.
I've tried to draw simple vector-symbols on lines. There were no problemes with closed vector-symbols but when I tried to draw non-closed vector symbols on lines the mapserver closed and filled them.
Is this perhaps an error in the source code? I'm using MapServer 4.0 and 4.1 on Windows 2000 and XP.
To better unterstand me I send you a small image of the drawn symbols beside a line.
The symbol-definition of a simple cross is the following:
SYMBOL
NAME "kreuz1"
TYPE VECTOR
POINTS
0.5 0
0.5 1
-99 -99
0 0.5
1 0.5
END
STYLE
1 15 1 15
END
END
The Layer in the Mapfile:
LAYER
NAME Linie2
TYPE LINE
STATUS DEFAULT
FEATURE
POINTS
2 80
95 80
END
END
CLASS
STYLE
SYMBOL "punkt" # this is just a filled circle for the basic line
SIZE 1
COLOR 0 0 0
END
STYLE
SYMBOL "kreuz1"
SIZE 12
COLOR 0 0 0
OFFSET 1 -12
END
END
END
Why does Mapserver close and fill the cross-symbol? The Mapserver draws the same symbol correctly when I'm using it on a point.
I can also use TrueTypeFonts as symbols on lines but I can't set the OFFSET-Parameters to draw the symbols beside the line. Mapserver draws always the TrueType-symbols on the line.
I could use a PIXMAP-symbol for the cross. I think that this is also possible with the OFFSET-Parameter.
Thank you for any help,
Karsten Hoffmann
_____________________________________________________________________
Endlich SMS mit Bildern versenden! Das Bild selbst ist dabei gratis,
Sie bezahlen lediglich den Versand. http://freemail.web.de/?mc=021195
Content-Type: image/x-png; name="symbol_line.png"
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename="symbol_line.png"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--STEFAN40bb07b775e6--
