[Mapserver-users] bug postgis query alias
Vladimir Guzmán bigfoot at main-task.com
Mon May 31 13:29:45 PDT 2004
Hello.
I'm implementing a gps tracking system.
I want to show the car's orientation like this:
http://maintask.com/test.png
The layer's data is something like this:
gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
rumbo,velocidad,gps_geom,oid from gps_vehi where tiempo>='2004-05-29
05:00:00' and tiempo<='2004-05-30 04:59:59') as foo using unique gid
using srid=1
The field 'sentido' contains '>'.
The problem is that if I use something like this:
gps_geom from (select gid,'>' as sentido,tiempo,360-rumbo+90 as
using srid=1
The query doesn't work.
So I had to create a column in potgres called 'sentido' and all the rows
containing '>'.
Is this a bug?
The rest of the layer:
LAYER
  NAME "puntosgps"
  CONNECTIONTYPE postgis
  CONNECTION "user=gps password=gps dbname=gps host=localhost"
  DATA "gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
using srid=1"
  TYPE POINT
PROJECTION
  "proj=latlong"
  "datum=WGS84"
END
  LABELANGLEITEM 'rumbo'
  LABELITEM 'sentido'
  CLASS
    NAME 'Parado'
    EXPRESSION ([velocidad] = 0)
    SIZE 14
    SYMBOL 'circle'
    COLOR 0 0 215
    OUTLINECOLOR 204 204 204
  END
  CLASS
    NAME '0-10'
    EXPRESSION ([velocidad] > 0 AND[velocidad] <= 10)
    SIZE 14
    SYMBOL 'circle'
    COLOR 255 255 204
    LABEL
      TYPE TRUETYPE
      FORCE TRUE
      FONT arial
      ANTIALIAS TRUE
      COLOR 0 0 0
      OUTLINECOLOR 255 255 255
      SIZE 8
    END
  END
Thanks a lot.
Vladimir Ilich Guzmán R.
http://maintask.com
More information about the MapServer-users mailing list
