mapserv install problem
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Mon Nov 1 19:49:54 EST 2004
Giving your layer a name will do the trick.
NAME "mypoint"
I think mode=browse expects more information.
Also I make my IMAGEURL relative to the top of my document root.
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Terry Brown
Sent: Monday, November 01, 2004 1:03 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] mapserv install problem
Trying to get a minimal demo running. Map file and template below, but
short story is that when going to
http://myhost.net/cgi-bin/mapserv?map=/home/ms/local/img/test0.map
The image is being generated in IMAGEPATH and is viewable via IMAGEURL
if entered directly, BUT whatever the first [square-bracket] expression
in the template is, output (view source) ends on the proceeding line.
Thanks for any clues.
MapServer version 4.2.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
Linux Mandrage 10.0 Apache
MAP
DEBUG on
SIZE 600 400
EXTENT 0 0 1000 1000
WEB
IMAGEPATH "/home/ms/local/img/"
IMAGEURL "http://myhost.net/mapimg/"
TEMPLATE "/home/ms/local/tmpl/test0.html"
END
LAYER
TYPE point
CLASS
COLOR 0 0 0
END
FEATURE
POINTS
50 500 500 100
END
END
END
END
with /home/ms/local/tmpl/test0.html
(replacing angle brackets with parentheses for email)
(html)
(head)
(title)test0(/title)
(/head)
(img src="[img]" border="0" width="300" height="400")
(/body)
(/html)
Terry Brown Natural Resources Research Institute
Research Associate 5013 Miller Trunk Highway
tbrown at nrri.umn.edu University of Minnesota, Duluth
Ph. 218 720 4345 Duluth, Minnesota 55811
Fax 218 720 4328 http://beaver.nrri.umn.edu/~tbrown/
