thread safe implementations
    Umberto Nicoletti
    unicoletti at PROMETEO.IT
    Mon Nov  8 01:22:23 PST 2004
Did you set LD_LIBRARY_PATH or as an alternative edited ld.so.conf and
run ldconfig (as root)?
Also try running ldconfig on libmapscript.so and see if reports missing
libraries.
HTH,
Umberto
On Mon, 2004-11-08 at 05:55, Dan Barron wrote:
> Sean/Umberto,
> I was able to compile java mapscript - however when I try to load the
> library within the sample java app to prove it works, I get an
> "UnsatisfiedLinkError" with "undefined symbol: msGMLWriteQuery" - I've
> looked around and can't seem to figure out what I am missing.  Any ideas
> why I am getting this?
> Thanks,
> Dan
> At 07:45 AM 11/4/2004, Sean Gillies wrote:
> >Dan,
> >Truly, the Java mapscript had been abandoned for a while.  Then Umberto
> >stepped forward and contributed a new Makefile and patches, and it seems
> >to be in a workable state.  I've also fixed the most obvious threading
> >issues in MapServer itself.
> >I'd really appreciate it if the two of you would download the new 4.4.0
> >beta releases and try them out.  Make some servlets and pound on them
> >and
> >see if Java mapscript is reliable.  I think this is really the only way
> >to know for sure.
> >BTW, once you have MapServer itself compiled, the Java Makefile in 4.4.0
> >works fine with FC2.
> >Sean
> >On Nov 4, 2004, at 8:12 AM, Dan Barron wrote:
> >>Umberto,
> >>I'm not going to try to recreate the functionality of the cgi - I'm not
> >>fully sure yet what absolute path I will take - I really have not done
> >>much
> >>threaded java code.  I've looked at the java mapscript - and your map
> >>server wiki entries for compiling java mapscript - I'm not convinced I
> >>have
> >>a good compile yet (platform is Fedora Core 2).  Is the java mapscript
> >>viable at this point?  I have read posts from earlier this year saying
> >>it
> >>looked abandoned?
> >>I would really like to get to an all java solution if possible - I
> >>currently use a combination of java/php (java opens a connection to a
> >>php
> >>script then parses the returned data) - not the best but it seems to
> >>work
> >>fine under light loads.
> >>I'd be interested to hear more about what you are up to - it sounds
> >>interesting.  I would really like to just build a threaded front end
> >>(maybe
> >>a thread pool?) to the map server functionality via java mapscript and
> >>nothing more.
> >>Thanks,
> >>Dan
> >>At 11:51 PM 11/3/2004, unicoletti at prometeo.it wrote:
> >>>Dan,
> >>>if by creating a java implementation you mean writing a web app to
> >>>deliver the
> >>>same (or  subset) of the functionality the cgi does, then I am
> >>>writing one.
> >>>I think I am one of the few java mapscript users around :-)
> >>>Regards,
> >>>umberto
> >>>Quoting Sean Gillies <sgillies at FRII.COM>:
> >>>>Dan,
> >>>>It's not clear to me what you mean by creating a java implementation
> >>>>on your own.  Implementation of what?  Do you mean a programming API
> >>>>like the php mapscript module?
> >>>>If this is what you mean, you should look at the Java stuff that
> >>>>you can generate using SWIG.  In mapserver versions 4.2.4+ and in
> >>>>the 4.4.0 beta1 there is a Java makefile under
> >>>>mapserver/mapscript/java.
> >>>>It seems to work, but as I've said -- I'm not a Java user and so am
> >>>>not beating on the Java mapscript module heavily enough or often
> >>>>enough to say anything about its readiness.
> >>>>Sean
> >>>>On Nov 3, 2004, at 10:37 AM, Dan Barron wrote:
> >>>>>Hmmm - I was really hoping someone had done (or attempted) a java
> >>>>>implementation - I'm not versed in Zope or Python.  Well, I guess I
> >>>>>will
> >>>>>attempt to create a java implementation on my own.
> >>>>>Thanks Sean.
> >>>>>Dan
> >>>>>At 01:10 PM 11/2/2004, Sean Gillies wrote:
> >>>>>>On Nov 2, 2004, at 10:47 AM, Dan Barron wrote:
> >>>>>>>Hello,
> >>>>>>>Just curious what the current consensus and recommendations are
> >>>>>>>for
> >>>>>>>creating a thread safe front end or wrapper for mapserver in
> >>>>>>>either
> >>>>>>>php or
> >>>>>>>java? I'm assuming that mapserver is still not thread safe - that
> >>>>>>>correct?
> >>>>>>>Thanks!
> >>>>>>>Dan
> >>>>>>Dan,
> >>>>>>I caught and fixed three sources of potential threading problems
> >>>>>>before
> >>>>>>the 4.2.4 release and these fixes will also be in 4.4.0.  I think
> >>>>>>we're
> >>>>>>close to thread safety, but it's hard to say without more testing.
> >>>>>>  As
> >>>>>>far as I know, my ZMapServer (Zope + Python mapscript) software is
> >>>>>>the
> >>>>>>only thing out there that is using MapServer in a multi-threaded
> >>>>>>environment.  It works, but is not a complete proof of thread
> >>>>>>safety.
> >>>>>>There remains much work to be done to in improving MapServer's
> >>>>>>threaded performance.  The single lexer for parsing mapfiles and
> >>>>>>class expressions is a bottleneck that will be addressed in the
> >>>>>>future.
> >>>>>>cheers,
> >>>>>>Sean
> >>>>>>Sean Gillies
> >>>>>>sgillies at frii dot com
> >>>>>>http://users.frii.com/sgillies
More information about the MapServer-users
