thread safe implementations
Umberto Nicoletti
unicoletti at PROMETEO.IT
Mon Nov 8 05:14:08 EST 2004
After more careful reading I found an error, sorry
On Mon, 2004-11-08 at 10:22, Umberto Nicoletti wrote:
> Did you set LD_LIBRARY_PATH or as an alternative edited ld.so.conf and
> run ldconfig (as root)?
> Also try running ldconfig on libmapscript.so and see if reports missing
> libraries.
Run ldd, not ldconfig. You may try ldd -r , this would report missing
functions and data (see man ldd).
BTW: what platform are you running (Linux/GNU I assume)?
Umberto
> HTH,
> Umberto
> On Mon, 2004-11-08 at 05:55, Dan Barron wrote:
> > Sean/Umberto,
> > I was able to compile java mapscript - however when I try to load the
> > library within the sample java app to prove it works, I get an
> > "UnsatisfiedLinkError" with "undefined symbol: msGMLWriteQuery" - I've
> > looked around and can't seem to figure out what I am missing. Any ideas
> > why I am getting this?
> > Thanks,
> > Dan
> > At 07:45 AM 11/4/2004, Sean Gillies wrote:
> > >Dan,
> > >Truly, the Java mapscript had been abandoned for a while. Then Umberto
> > >stepped forward and contributed a new Makefile and patches, and it seems
> > >to be in a workable state. I've also fixed the most obvious threading
> > >issues in MapServer itself.
> > >I'd really appreciate it if the two of you would download the new 4.4.0
> > >beta releases and try them out. Make some servlets and pound on them
> > >and
> > >see if Java mapscript is reliable. I think this is really the only way
> > >to know for sure.
> > >BTW, once you have MapServer itself compiled, the Java Makefile in 4.4.0
> > >works fine with FC2.
> > >Sean
> > >On Nov 4, 2004, at 8:12 AM, Dan Barron wrote:
> > >>Umberto,
> > >>I'm not going to try to recreate the functionality of the cgi - I'm not
> > >>fully sure yet what absolute path I will take - I really have not done
> > >>much
> > >>threaded java code. I've looked at the java mapscript - and your map
> > >>server wiki entries for compiling java mapscript - I'm not convinced I
> > >>have
> > >>a good compile yet (platform is Fedora Core 2). Is the java mapscript
> > >>viable at this point? I have read posts from earlier this year saying
> > >>it
> > >>looked abandoned?
> > >>I would really like to get to an all java solution if possible - I
> > >>currently use a combination of java/php (java opens a connection to a
> > >>php
> > >>script then parses the returned data) - not the best but it seems to
> > >>work
> > >>fine under light loads.
> > >>I'd be interested to hear more about what you are up to - it sounds
> > >>interesting. I would really like to just build a threaded front end
> > >>(maybe
> > >>a thread pool?) to the map server functionality via java mapscript and
> > >>nothing more.
> > >>Thanks,
> > >>Dan
> > >>At 11:51 PM 11/3/2004, unicoletti at prometeo.it wrote:
> > >>>Dan,
> > >>>if by creating a java implementation you mean writing a web app to
> > >>>deliver the
> > >>>same (or subset) of the functionality the cgi does, then I am
> > >>>writing one.
> > >>>I think I am one of the few java mapscript users around :-)
> > >>>Regards,
> > >>>umberto
> > >>>Quoting Sean Gillies <sgillies at FRII.COM>:
> > >>>>Dan,
> > >>>>It's not clear to me what you mean by creating a java implementation
> > >>>>on your own. Implementation of what? Do you mean a programming API
> > >>>>like the php mapscript module?
> > >>>>If this is what you mean, you should look at the Java stuff that
> > >>>>you can generate using SWIG. In mapserver versions 4.2.4+ and in
> > >>>>the 4.4.0 beta1 there is a Java makefile under
> > >>>>mapserver/mapscript/java.
> > >>>>It seems to work, but as I've said -- I'm not a Java user and so am
> > >>>>not beating on the Java mapscript module heavily enough or often
> > >>>>enough to say anything about its readiness.
> > >>>>Sean
> > >>>>On Nov 3, 2004, at 10:37 AM, Dan Barron wrote:
> > >>>>>Hmmm - I was really hoping someone had done (or attempted) a java
> > >>>>>implementation - I'm not versed in Zope or Python. Well, I guess I
> > >>>>>will
> > >>>>>attempt to create a java implementation on my own.
> > >>>>>Thanks Sean.
> > >>>>>Dan
> > >>>>>At 01:10 PM 11/2/2004, Sean Gillies wrote:
> > >>>>>>On Nov 2, 2004, at 10:47 AM, Dan Barron wrote:
> > >>>>>>>Hello,
> > >>>>>>>Just curious what the current consensus and recommendations are
> > >>>>>>>for
> > >>>>>>>creating a thread safe front end or wrapper for mapserver in
> > >>>>>>>either
> > >>>>>>>php or
> > >>>>>>>java? I'm assuming that mapserver is still not thread safe - that
> > >>>>>>>correct?
> > >>>>>>>Thanks!
> > >>>>>>>Dan
> > >>>>>>Dan,
> > >>>>>>I caught and fixed three sources of potential threading problems
> > >>>>>>before
> > >>>>>>the 4.2.4 release and these fixes will also be in 4.4.0. I think
> > >>>>>>we're
> > >>>>>>close to thread safety, but it's hard to say without more testing.
> > >>>>>> As
> > >>>>>>far as I know, my ZMapServer (Zope + Python mapscript) software is
> > >>>>>>the
> > >>>>>>only thing out there that is using MapServer in a multi-threaded
> > >>>>>>environment. It works, but is not a complete proof of thread
> > >>>>>>safety.
> > >>>>>>There remains much work to be done to in improving MapServer's
> > >>>>>>threaded performance. The single lexer for parsing mapfiles and
> > >>>>>>class expressions is a bottleneck that will be addressed in the
> > >>>>>>future.
> > >>>>>>cheers,
> > >>>>>>Sean
> > >>>>>>Sean Gillies
> > >>>>>>sgillies at frii dot com
> > >>>>>>http://users.frii.com/sgillies
