RES: [UMN_MAPSERVER-USERS] RES: [UMN_MAPSERVER-USERS] layer
group(s)?
Murilo Lacerda Yoshida
murilo.yoshida at AGX.COM.BR
Mon Nov 8 18:01:41 EST 2004
I guess I understood the suggestion, but in that case I would have two
layers, right?
If I have only one group then your suggestion works great for me. If
not it doesn't work.
The problem is that I turn layers on and off in may app using the
group name. If I have two layers with the same name there is the chance
that I set one off and the other one is still on.
I had to set two groups on a layer because there it kind of belongs to
two different groups...
But I solved the problem, but not in the smartest way, but solved. If
there is a smartest way tell me please.
Thanks,
Murilo
-----Mensagem original-----
De: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Em
nome de Eric Bridger
Enviada em: segunda-feira, 8 de novembro de 2004 18:02
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: Re: [UMN_MAPSERVER-USERS] RES: [UMN_MAPSERVER-USERS] layer
group(s)?
On Mon, 2004-11-08 at 16:15, Murilo Lacerda Yoshida wrote:
> I tried here to do that... Apparently if you set two groups on one
> layer, the last group assigned is the one that counts... The other one
> is forgotten ... I'll change the order of the groups here and see what
> happens.
> The strange thing is that mapserver doesn't show an error for that.
> Thanks Eric,
> Murilo
I'm not sure if you understood my suggestion. Create a new layer
identical to the first layer except for the GROUP name. The layer will
be included in both groups.
LAYER
NAME "layer_one"
GROUP "group_one"
END
LAYER
NAME "layer_one"
GROUP "group_two"
END
