ogr vrt with php_mapscript
    Frank Warmerdam
    warmerdam at POBOX.COM
    Wed Nov 10 06:08:59 PST 2004
Olivier Gayte wrote:
> Franck,
> It has taken some delay because I had never used gdb until now.
> You will find herewith the traceback when php_mapscript crashes.
> /usr/local/lib/libgdal.so.1 points towards libgdal.so.1.5.0
> May I do anything else to help you in your investigation?
Oliver,
The fact that the traceback shows a crash down inside the mysql odbc
driver on the SQLConnect() suggests to me that the issue is not specifically
mapserver or OGR but the odbc configuration.  The arguments to SQLConnect()
look reasonable ... certainly no obvious reason for a crash.  I really don't
know what to suggest.
Best regards,
More information about the MapServer-users
