need help to begin - very newbee
David Fawcett
David.Fawcett at STATE.MN.US
Wed Nov 10 13:13:53 EST 2004
Joseph,
What do you mean by 'dump of the map'?
Is it an image of the map (as you would expect from mode=map)?
Is it a dump of the text of the map file?
Did you get any sort of error message?
David.
>>> Joseph Norris <sirronj at PACBELL.NET> 11/10/2004 11:11:39 AM >>>
I have named the executable mapserv.cgi - and it works just fine on the
demo
model that I have obtained with mapserv. I am doing something wrong
with
the mapfile I think.
#Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print
@c=map chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
Behalf Of David Fawcett
Sent: Wednesday, November 10, 2004 9:02 AM
To: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] need help to begin - very newbee
Joseph,
This may not be your entire problem, but you need to modify the URL.
I
believe that you have the wrong suffix on the name of the mapserv
binary
file.
Use this if you are on Windows:
http://mco.communityservers.com/cgi-bin/mapserv.exe?map=/usr/local/apache/ht
docs/mco.communityservers.com/htdocs/maps/cal/cal.map&mode=map
Or this if you are on 'nix:
http://mco.communityservers.com/cgi-bin/mapserv?map=/usr/local/apache/ht
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> Joseph Norris <sirronj at PACBELL.NET> 11/10/2004 10:45:52 AM >>>
Hello to all,
I have successfully installed mapserver and I have the following
files:
B_Major_Cities_2.dbf
B_Major_Cities_2.prj
B_Major_Cities_2.shp
B_Major_Cities_2.shx
Country_Boundaries_3.dbf
Country_Boundaries_3.prj
Country_Boundaries_3.shp
Country_Boundaries_3.shx
Rivers_2.dbf
Rivers_2.prj
Rivers_2.shp
Rivers_2.shx
Streets_and_Railroads_1.dbf
Streets_and_Railroads_1.prj
Streets_and_Railroads_1.shp
Streets_and_Railroads_1.shx
Water_Bodies_2.dbf
Water_Bodies_2.prj
Water_Bodies_2.shp
Water_Bodies_2.shx
I have the following map file:
MAP
IMAGETYPE GIF
EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
SIZE 500 400
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# Start of LAYER DEFINITIONS
LAYER # California polygon layer begins here
NAME "Country_Boundaries_3"
DATA "Country_Boundaries_3"
STATUS DEFAULT
TYPE POLYGON
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
I then do the following:
http://mco.communityservers.com/cgi-bin/mapserv.cgi?map=/usr/local/apache/ht
in my browser - but I get now dump of the map. I have been over the
tutorial ( - please - if anyone has a more simplified tutorial - let
me
know ) but I do not see where I am in error.
Thanks to all
@c=map chr
