wcs issues on getting data
Frank Warmerdam
warmerdam at POBOX.COM
Wed Nov 10 13:40:23 EST 2004
Nuno GIL wrote:
>Dear listers,
>I've installed mapserver in order to use its wcs
>capabilities.
>The GetCapabilities request works fine, the problem is
>when I try to use the GetCoverage request. Actually I
>don't receive any error message, but the received file
>is empty.
>I'm querying the server with this request:
>http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?REQUEST=GetCoverage&COVERAGE=l5&SERVICE=WCS&map=/ge/data/iceds/alpha/umms/wcs_land3.map&BBOX=48.5,-21.5,48.7,-21.3&FORMAT=GEOTIFF_RGB&CRS=EPSG:4326&RESX=0.00027778&RESY=0.00027778
>Just to try and sort out the problem, I reduced the
>data being served to only a simple image with one
>channel (no tiles), no results as well...
Nuno,
I notice you have no coordinate system defined for your image as a
PROJECTION
block. I would encourage you to add a block like this in your layer:
PROJECTION
"+init=epsg:4326"
END
If it makes things work, please update the WCS wiki docs to mention this
requirement.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
