wcs issues on getting data
Nuno GIL
nunoragil at YAHOO.COM
Wed Nov 10 16:49:27 EST 2004
Hi Pericles,
Let me just point out the results of your suggestions:
1. Yes, by requesting
http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?map=/ge/data/iceds/alpha/umms/wcs_land3.map&layer=L5&mode=map
A map is shown
2. This image is a 8-bit one. I've included:
OUTPUTFORMAT
NAME GEOTIFF_8b
DRIVER "GDAL/GTiff"
IMAGEMODE PC256
END
With the original GetCoverage request the file is
still empty
3. Already inserted the projection block Frank
suggested and no good result as well
This is getting difficult... Thanks for your time and
help,
Nuno
--- "Pericles S. Nacionales" <nacional at CBS.UMN.EDU>
wrote:
> On Wed, 2004-11-10 at 10:31 -0800, Nuno GIL wrote:
> > Dear listers,
> > I've installed mapserver in order to use its wcs
> > capabilities.
> > The GetCapabilities request works fine, the
> problem is
> > when I try to use the GetCoverage request.
> Actually I
> > don't receive any error message, but the received
> file
> > is empty.
> > I'm querying the server with this request:
http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?REQUEST=GetCoverage&COVERAGE=l5&SERVICE=WCS&map=/ge/data/iceds/alpha/umms/wcs_land3.map&BBOX=48.5,-21.5,48.7,-21.3&FORMAT=GEOTIFF_RGB&CRS=EPSG:4326&RESX=0.00027778&RESY=0.00027778
> > Does anyone understands what is going wrong? Any
> help
> > would be much appreciated.
> Nuno,
> 1. Are you able to see the image when you run a
> regular MapServer CGI
> request (i.e.
http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?map=/ge/data/iceds/alpha/umms/wcs_land3.map&layer=LC5&mode=map)?
> 2. Is your image 16- or 8-bit? If 8-bit, perhaps
> you should replace
> IMAGEMODE INT16 with IMAGEMODE PC256 in OUTPUTFORMAT
> (also replace the
> NAME accordingly).
> 3. What Frank said in another post.
> Cheers!
> Perry
> Pericles S. Nacionales <nacional at cbs.umn.edu>
__________________________________
Do you Yahoo!?
Check out the new Yahoo! Front Page.
www.yahoo.com
