please - please - can anybody shed any light on what I am
doing wrong?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Nov 11 14:53:42 EST 2004
When I hit the URL you listed it says:
msLoadMap(): Unable to access file.
(/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/cal/cal.map)
So I would check your path and your permissions
-Steve
Stephen Woodbridge wrote:
> Joseph,
> You DATAPATH is relative to your mapfile unless you specify it as an
> absolute path. I would start there. Also if you can load Netscape then
> you can right click the broken image icon and select view image and it
> will display any error messages that mapserver coughs up.
> -Steve
> Joseph Norris wrote:
>> Group,
>> Here I am again:
>> I have this link:
>> http://mco.communityservers.com/cgi-bin/mapserv?map=/usr/local/apache/htdocs
>> /mco.communityservers.com/htdocs/maps/cal/cal.map&mode=map
>> and this map file
>> MAP
>> NAME TESTMAP
>> STATUS ON
>> EXTENT -1375383.89811082 -7278971.22201064 16216802.1381132
>> 10313214.8142134
>> IMAGETYPE PNG
>> SIZE 600 600
>> SHAPEPATH "data"
>> IMAGECOLOR 255 255 255
>> WEB
>> METADATA
>> "key1" "value1"
>> "key2" "value2"
>> "key3" "value3"
>> "key4" "value4"
>> END
>> END
>> LAYER
>> NAME "calif_co_st"
>> TYPE POLYGON
>> DATA "calif_co_st"
>> STATUS DEFAULT
>> END
>> END
>> I still getting nothing but this on my map ( right-click properties ):
>> The image
>> "http://mco.communityservers.com/cgi-bin/mapserv?map=/usr/local/apache/htdoc
>> s/mco.communityservers.com/htdocs/maps/cal/cal.map&mode=map" cannot be
>> displayed, because it contains errors.
>> And yet - when I move the tests directory into my http tree like this
>> /mco.communityservers.com/htdocs/tests/test.map&mode=map
>> I get what the mapserver tests are supposed to give - is there something
>> about my shape files I should know about?
>> Please - anything at all would be helpful.
