please - please - can anybody shed any light on what I am
doing wrong?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Nov 11 15:07:41 EST 2004
Joseph,
I'm not sure your extents are correct:
EXTENTS xmin ymin xmax ymax
it looks like you have xmin xmax ymin ymax. What to you get for an image
when you use shp2img utility?
-Steve
Joseph Norris wrote:
> I made a change - checked the permissions:
> Everything set to apache and with read/write/exec for apache
> This is the same as the
> http://mco.communityservers.com/cgi-bin/mapserv?map=/usr/local/apache/htdocs
> /mco.communityservers.com/htdocs/tests/test.map&mode=map
> This new url - simplified
> /mco.communityservers.com/htdocs/maps/cal.map&mode=map
> The two directory permission structures are the exact same.
> #Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
> $_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
> 68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
> Behalf Of Stephen Woodbridge
> Sent: Thursday, November 11, 2004 11:54 AM
> To: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] please - please - can anybody shed any
> light on what I am doing wrong?
> When I hit the URL you listed it says:
> msLoadMap(): Unable to access file.
> (/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/cal/cal.map)
> So I would check your path and your permissions
> -Steve
> Stephen Woodbridge wrote:
>>Joseph,
>>You DATAPATH is relative to your mapfile unless you specify it as an
>>absolute path. I would start there. Also if you can load Netscape then
>>you can right click the broken image icon and select view image and it
>>will display any error messages that mapserver coughs up.
>>-Steve
>>>Group,
>>>Here I am again:
>>>I have this link:
>>>/mco.communityservers.com/htdocs/maps/cal/cal.map&mode=map
>>>and this map file
>>>MAP
>>> NAME TESTMAP
>>> STATUS ON
>>> EXTENT -1375383.89811082 -7278971.22201064 16216802.1381132
>>>10313214.8142134
>>> IMAGETYPE PNG
>>> SIZE 600 600
>>> SHAPEPATH "data"
>>> IMAGECOLOR 255 255 255
>>> WEB
>>> METADATA
>>> "key1" "value1"
>>> "key2" "value2"
>>> "key3" "value3"
>>> "key4" "value4"
>>> END
>>> END
>>> LAYER
>>> NAME "calif_co_st"
>>> TYPE POLYGON
>>> DATA "calif_co_st"
>>> STATUS DEFAULT
>>> END
>>>END
>>>I still getting nothing but this on my map ( right-click properties ):
>>>The image
> "http://mco.communityservers.com/cgi-bin/mapserv?map=/usr/local/apache/htdoc
>>>s/mco.communityservers.com/htdocs/maps/cal/cal.map&mode=map" cannot be
>>>displayed, because it contains errors.
>>>And yet - when I move the tests directory into my http tree like this
>>>I get what the mapserver tests are supposed to give - is there something
>>>about my shape files I should know about?
>>>Please - anything at all would be helpful.
