please - please - can anybody shed any light on what I am
doing wrong?
Romolo Manfredini
romoloman at HOTMAIL.COM
Thu Nov 11 16:24:42 EST 2004
Try to remove the prj file, seems to be broken and probably prevents the
opening of the file.
Furthermore the extents of the shapefile are [minx] [miny] [maxx] [maxy]
5895561.577 -191512.795 8945856.680 3225756.404
Best Regards,
Romolo Manfredini
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, November 11, 2004 8:59 PM
Subject: Re: [UMN_MAPSERVER-USERS] please - please - can anybody shed any
light on what I am doing wrong?
> I made a change - checked the permissions:
> Everything set to apache and with read/write/exec for apache
> This is the same as the
http://mco.communityservers.com/cgi-bin/mapserv?map=/usr/local/apache/htdocs
> /mco.communityservers.com/htdocs/tests/test.map&mode=map
> This new url - simplified
> /mco.communityservers.com/htdocs/maps/cal.map&mode=map
> The two directory permission structures are the exact same.
> #Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map
chr
$_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
> 68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu]On
> Behalf Of Stephen Woodbridge
> Sent: Thursday, November 11, 2004 11:54 AM
> To: MAPSERVER-USERS at lists.umn.edu
> When I hit the URL you listed it says:
> msLoadMap(): Unable to access file.
(/usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/cal/cal.map)
> So I would check your path and your permissions
> -Steve
> Stephen Woodbridge wrote:
> > Joseph,
> > You DATAPATH is relative to your mapfile unless you specify it as an
> > absolute path. I would start there. Also if you can load Netscape then
> > you can right click the broken image icon and select view image and it
> > will display any error messages that mapserver coughs up.
> > -Steve
> > Joseph Norris wrote:
> >> Group,
> >> Here I am again:
> >> I have this link:
> >> /mco.communityservers.com/htdocs/maps/cal/cal.map&mode=map
> >> and this map file
> >> MAP
> >> NAME TESTMAP
> >> STATUS ON
> >> EXTENT -1375383.89811082 -7278971.22201064 16216802.1381132
> >> 10313214.8142134
> >> IMAGETYPE PNG
> >> SIZE 600 600
> >> SHAPEPATH "data"
> >> IMAGECOLOR 255 255 255
> >> WEB
> >> METADATA
> >> "key1" "value1"
> >> "key2" "value2"
> >> "key3" "value3"
> >> "key4" "value4"
> >> END
> >> END
> >> LAYER
> >> NAME "calif_co_st"
> >> TYPE POLYGON
> >> DATA "calif_co_st"
> >> STATUS DEFAULT
> >> END
> >> END
> >> I still getting nothing but this on my map ( right-click properties ):
> >> The image
"http://mco.communityservers.com/cgi-bin/mapserv?map=/usr/local/apache/htdoc
> >> s/mco.communityservers.com/htdocs/maps/cal/cal.map&mode=map" cannot be
> >> displayed, because it contains errors.
> >> And yet - when I move the tests directory into my http tree like this
> >> I get what the mapserver tests are supposed to give - is there
something
> >> about my shape files I should know about?
> >> Please - anything at all would be helpful.
