Join shape and dbms data: OGR?
Michael Schulz
mschulz at WEBGIS.DE
Tue Nov 16 04:16:07 EST 2004
yes this is working, i haven't tried regexps but string and logical expressions are working and
mapserver is classifying the shapefile according to the joined attributes. fnpf.shp only has the
relation key PID in its .dbf attribute table.
CONNECTIONTYPE OGR
CONNECTION "c:\mstest\data\fnpf.shp" # shapefile holding only geometry and PID in .dbf
DATA "SELECT * FROM fnpf LEFT JOIN 'ODBC:fnp'.fnp ON fnpf.PID=fnp.PID"
CLASS
EXPRESSION ([AZJAHR] = 0)
STYLE
COLOR 255 0 150
END
END
CLASS
EXPRESSION ([AZJAHR] = 1)
STYLE
COLOR 255 150 0
END
END
CLASS
EXPRESSION ([AZJAHR] > 1)
STYLE
COLOR 0 150 150
END
END
Cheers, Michael
Emil Zegers schrieb:
> Hello Michael,
> I have a question for you about this approach: when using this kind of join were you able to classify data based on the joined attributes and display this in the map image?
> I'm asking this because with normal join operation it is not possible to create thematic maps based on the joined attributes.
> If classifcation works based on this approach the enhancement request I put in bugzilla (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=674) can be closed.
> I would be very happy if classifying on joined attributes works this way (had no time to test this approach yet).
> Regards,
> Emil Zegers
> Hi Frank,
> thanks for your answer. It is working perfectly now.
> For the moment it is only one table i want to join to the geometry of the shp-file, so at first
> sight performance is good, but i will play with the indexes a little.
> For all who have to use a similar approach here's a mapfile snipplet:
> LAYER
> CONNECTIONTYPE OGR
> # join to systemDSN fnp (here msaccess-db "fnp.mdb" with table fnp) on attribute PID,
> # now all fields of the db are also accessible for mapserver, e.g. "AZJAHR"
> LABELITEM "AZJAHR"
> END
> Thanks, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
