Stack trace from timing out PHP MapScript CGI
    Doug
    ummmmm at MYREALBOX.COM
    Tue Nov 16 14:02:06 PST 2004
I posted here a couple of weeks ago asking about our CGI PHP MapScript
application that appears to quit responding periodically.
<http://lists.umn.edu/cgi-bin/wa?A2=ind0410&L=mapserver-users&T=0&F=&S=&X=30762F284AB96B2313&P=50619>
Context refresher:
MapServer/MapScript 4.2.5, PHP 4.3.8 (cgi), PostgreSQL 7.4.3, PostGIS 0.8.2,
Apache 2.0.51, Fedora Core 2 SMP (Dual CPU 2GHz P4).
Application posts to PHP file, which does a map->draw() (of shapefile layers),
followed by a couple of queryByRect() on non-shown (PostGIS) layers, manual
point->draw()s with custom, numbered labels, then a map->save().
I had observed that regularly the PHP processes seem to hang or stall, so
somebody on #Mapserver suggested that I compile with debug options and try to
obtain a stack trace when this happens.
Unfortunately, I've been unable to duplicate the exact situation, but I have
seen some similar ones where client requests to the PHP CGIs stack up and time
out.  In fact, I can force that to happen simply by getting several clients to
make a simultaneous request of the server.  Today, I forced 7 such
simultaneous requests, and every single one of them timed out.  Normally, when
this kind of condition occurs, the MapServer stderr also reports:
[Mon Nov 15 21:17:39 2004] [error] [client 32.83.226.185] PHP Fatal error:
Maximum execution time of 30 seconds exceeded in var/www/html/offender/map.php
on line 87
But this didn't happen in my forced test today.  i.e. my clients timed out,
but the PHP CGIs didn't seem to.  Obviously, I need to play with either my
client or server timeouts, but can anything useful be determined by these
stack traces?:
 From last night's "natural" slowdown (which was so bad that most/all requests
during a 30 minute period timed out):
#0  0x00ac8402 in ?? ()
#1  0x005e11ea in lseek64 () from /lib/tls/libc.so.6
#2  0x00581a37 in _IO_file_seek_internal () from /lib/tls/libc.so.6
#3  0x0058175a in _IO_new_file_seekoff () from /lib/tls/libc.so.6
#4  0x00578a2a in _IO_seekoff_unlocked () from /lib/tls/libc.so.6
#5  0x0057e08d in fseek () from /lib/tls/libc.so.6
#6  0x0030b5c2 in msSHPReadBounds (psSHP=0x8f0d858, hEntity=36339712,
padBounds=0xfef2dd70) at mapshape.c:1163
#7  0x0030bb32 in msSHPWhichShapes (shpfile=0x8fcebc0, rect= {minx =
511572.85125965299, miny = 3562542.8004036499, maxx = 513272.85125965299, maxy
= 3563562.8004036499}, debug=0) at mapshape.c:1338
#8  0x0032e14a in msLayerWhichShapes (layer=0x8d92198, rect= {minx =
= 3563562.8004036499}) at maplayer.c:198
#9  0x00330a02 in msDrawVectorLayer (map=0xf6ff3008, layer=0x8d92198,
image=0x8f0e7e0) at mapdraw.c:751
#10 0x00330711 in msDrawLayer (map=0xf6ff3008, layer=0x8d92198,
image=0x8f0e7e0) at mapdraw.c:639
#11 0x00330028 in msDrawMap (map=0xf6ff3008) at mapdraw.c:317
#12 0x0030006f in mapObj_draw (self=0xf6ff3008) at mapscript_i.c:419
#13 0x002f2279 in php3_ms_map_draw (ht=0, return_value=0x8d550ac,
this_ptr=0x8d5502c, return_value_used=1) at php_mapscript.c:3311
#14 0x0811dcfa in execute (op_array=0x8d650d4) at
/usr/src/php-4.3.8/Zend/zend_execute.c:1635
#15 0x0811dac9 in execute (op_array=0x8d425dc) at
/usr/src/php-4.3.8/Zend/zend_execute.c:1679
#16 0x0811dac9 in execute (op_array=0x8d3ef8c) at
#17 0x08112fd3 in zend_execute_scripts (type=8, retval=0x0, file_count=3) at
/usr/src/php-4.3.8/Zend/zend.c:891
#18 0x080f089c in php_execute_script (primary_file=0xfef30780)at
/usr/src/php-4.3.8/main/main.c:1734
#19 0x081220b2 in main (argc=1, argv=0xfef30844) at
/usr/src/php-4.3.8/sapi/cgi/cgi_main.c:1592
 From today's artificial one (which lasted less than a minute after the
simultaneous requests were finished):
#0  0x005fc7a2 in _dl_sysinfo_int80 () from /lib/ld-linux.so.2
#1  0x0050f85a in lseek64 () from /lib/tls/libc.so.6
#2  0x004afbf7 in _IO_file_seek_internal () from /lib/tls/libc.so.6
#3  0x004af91a in _IO_new_file_seekoff () from /lib/tls/libc.so.6
#4  0x004a6bea in _IO_seekoff_unlocked () from /lib/tls/libc.so.6
#5  0x004ac24d in fseek () from /lib/tls/libc.so.6
#6  0x0080c5c2 in msSHPReadBounds (psSHP=0x9d5e190, hEntity=63127552,
padBounds=0xfeebf8a0) at mapshape.c:1163
#7  0x0080cb32 in msSHPWhichShapes (shpfile=0x9e1f860, rect={minx =
400998.78413511597, miny = 3697149.2200513999, maxx = 402698.78413511597, maxy
= 3698169.2200513999}, debug=0) at mapshape.c:1338
#8  0x0082f14a in msLayerWhichShapes (layer=0x9be1d60, rect={minx =
= 3698169.2200513999}) at maplayer.c:198
#9  0x00831a02 in msDrawVectorLayer (map=0xf6fc4008, layer=0x9be1d60,
image=0x9d5e388) at mapdraw.c:751
#10 0x00831711 in msDrawLayer (map=0xf6fc4008, layer=0x9be1d60,
image=0x9d5e388) at mapdraw.c:639
#11 0x00831028 in msDrawMap (map=0xf6fc4008) at mapdraw.c:317
#12 0x0080106f in mapObj_draw (self=0xf6fc4008) at mapscript_i.c:419
#13 0x007f3279 in php3_ms_map_draw (ht=0, return_value=0x9ba4254,
     this_ptr=0x9ba41d4, return_value_used=1) at php_mapscript.c:3311
#14 0x0811dcfa in execute (op_array=0x9bb4c84)  at
#15 0x0811dac9 in execute (op_array=0x9b917dc)  at
#16 0x0811dac9 in execute (op_array=0x9b8deec) at
#18 0x080f089c in php_execute_script (primary_file=0xfeec22b0) at
#19 0x081220b2 in main (argc=1, argv=0xfeec2374) at
Basically, it seems that it takes very few simultaneous requests for our
system to fall behind.  If it gets even more requests than that minimum, it
seems to be unable to recover for sometimes half an hour or more.
I've seen people claiming very good performance of similar applications on
slower systems, so I'm trying to understand what could be causing this behaviour.
Here's hoping the stack traces will at least help us pinpoint the likely
cuplrit(s).
Doug
More information about the MapServer-users
