Ok - I don't understand - still another issue
    Stephen Woodbridge
    woodbri at SWOODBRIDGE.COM
    Tue Nov 16 15:02:49 PST 2004
Joseph,
I don't have "OUTLINECOLOR 0 0 0" defined in your CLASS block. You need to
get a copy of the Mapfile Reference  from the web site and experiment with
the various options and/or look at the demo mapfile and read up on any
options that they are using that you are not using to better understand
what all the options do. There are a lot of them and it requires a little
reading and experimenting.
-Steve
Joseph Norris said:
> To all,
> You have been very helpful and most patient!
> I pull my shp,dbf,shx files into fGIS windows desktop and I see California
> all divided up by its counties according to the dbf file.  However when I
> try to see the same thing with the same files via mapserver  all I get is
> the grayish shadowy California view - no division lines at all.  Am I
> missing something in my class statement or what?
> Thanks again.
> I now have my map file like this:
> MAP
>   NAME TESTMAP
>   STATUS ON
>   EXTENT  5996283.000 2041773.253 6327844.002 2497976.501
>   IMAGETYPE GIF
>   SIZE 600 600
>   SHAPEPATH "data"
>   IMAGECOLOR 255 255 255
>   WEB
>    HEADER header.html
>    FOOTER footer.html
>    IMAGEPATH
> /usr/local/apache/htdocs/mco.communityservers.com/htdocs/maps/tmp/
>    IMAGEURL  /maps/tmp/
>    TEMPLATE map_template.html
>   END
>   LAYER
>     NAME "Mendo_Zip"
>     TYPE POLYGON
>     DATA "Mendo_Zip"
>     STATUS DEFAULT
>     CLASS
>         COLOR 225 225 185
>     END
>   END
> END
> #Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map
> chr
> $_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
> 68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
More information about the MapServer-users
